On 6/19/2024 at 9:39 PM, AndyHull said:
There are still quite a few around, but you have to be patient.
Absolutely they do, just because ebay doesn't cough up much these days Carboot day today,here are 4 that cost me 12 quid for all. The Sekonda is immaculate, had the back off and very possibly only a service required. Both timex also work, though the 70's style not for long the other has been running since 10.oclock this morning,  the dial of that one looks half decent the glass lets it down and the Limit quite poor but case is good and i have the same one in black. I was ten minutes late of picking up a non working Bulova for the same 3 quid, but these are good, I'm especially liking the retro Timex.  Yes the 404 are out there, and no postage with these,this thread lives on Andy 👍
The 0.99p Casio MQ-24 turned up.
It is brand new, never worn, still with the plastic protection film on the front. RRP is apparently £59.00 but you can pick them up for less.
It did however have a flat battery, but since I have a bunch of brand new AG4, I picked up recently, that wasn't an issue.
Guess what I will be wearing in the garden tomorrow.
Edited by AndyHull
I had a spare 5 mins yesterday so I took a look at the first of the "three for a quid" I picked up recently.
A new battery, a new strap and a fumigation of the case and it looks like new.
Perhaps its most impressive feature is the lume. In the dark, it lights up like Hollywood nuclear spill, and even in daylight it has a slight glow. Well worth thirty three and a third pence I would say.
The second "three for a quid" got a new after-market band. I was going to go with a black one but plumped instead for a bright orange.
Described as "High Quality Rubber Wrist Strap For Casio MW-59 MW59 MQ-24 MQ24 MQ-71 MQ71 MQ-76 MQ76 Replacement Black Bracelet WatchBand Strap" on AliExpress, it cost a mere £1.75 plus vat, free shipping (as I was ordering other stuff, so combined shipping was free).
Add in a battery and I now have two MQ-24s that look like new.
Landed this Benrus within a quarter of the current 404 exchange rate, but with cheap shipping, so I'm counting it. Crystal is a lost cause, which sucks, because it's one of those that requires the ID and OD to match the case to close and seal... Bummer... Last time I attempted one of these, I had to find one with a slightly larger OD and shave it down, which was decidedly unfun. Kept would be vandals from opening/ruining it though, so that's a win! It's also missing the split stem crown, and the crown tube is somewhat less than circular. The case is all stainless though (one of my requirements to place any bid).
Inside is a 17 jewel ETA 1256, which is a pretty neat movement with some cool features. Very early automatic, evidenced by a lack of shock protection (it runs if you get it going, and has been running from the automatic wind during the time I've been typing this, so that bodes well). According to the link a few lines back there, it is the "prime father of all ETA selfwinding movements ever made". Neat! It has a "springless click reverser" with a "double click wheel". I'm not sure if that's exclusively dealing with the automatic works, or if it would wind both ways if I had a crown to wind it with. Very cool watch! If I can get the crystal and crown/stem sorted out, it'll make for a very nice watch! For now though, it goes into the project box.
I had some success paring down acrylic crystal lips by mounting a big blob of blue tack on the end of a cordless drill chuck.
You can centre it by squidging  the crystal around on the the blue tack till you are happy that it runs true.
Then its just a matter of using a little coarse sandpaper and some digital calipers to chase the size down to what you needed. Its a little crude, but since you are typically only removing a few tenths of a millimetre and acrylic sands down quickly, its is a lot easier than you might think. Practice on a few scrap crystals first.
The "blue tack chuck" also works for polishing acrylic crystals too.
Hot glue might also work, as it parts company from whatever it is stuck to with a little isopropanol, which shouldn't damage the crystal. I may give that a try.
I guess these qualify as 404's.  Freebies from a watchmaker friend of mine.  I guess he doesn't think that I am busy enough.
Waltham automatic with PUW 1463 movement.  17 jewels.  It's a runner.
I don't know the manufacturer of the "Time is Money" pocket watch.  My first experience with a pin set movement.  Pallet fork is all metal.  A few jewels are evident.  Time sets fine.  Trying to wind the mainspring has no resistance, so maybe a broken mainspring.  Balance seems good.  Looks like a mucky mess around the ratchet wheel.
Edited by gpraceman
Looking at it (the pin set) on this bigger screen, that center pivot is really hanging out there! I want to see more of that movement... Especially the all-metal pallet fork and the keyless works. Also, looks like she might have lost some balance screws along the way...
Edited by spectre6000
No missing balance screws.  No other markings to identify the manufacturer by.  Might be awhile before I get around to this project to see how it is constructed.
Oh wow! I didn't understand the "Time is Money" comment until that last photo. That is interesting... We need a date on that. Reminds me of this 19th century portrait of a guy with Jetsons glasses (actually for protection from the harmful effects of the light from whale oil lamps, whatever those effects were purported to be):
It's also on the back of the case.
This "twofer" just arrived. The Amida runs, but needs serviced and the Timex stutters forward a couple of seconds after a shake but doesn't run.  I suspect both will work just fine after a little TLC. I'll keep you posted on progress.
A 1972 Timex is on its way. Listed as "not working" (no surprise there) and "automatic" (it isn't).
It looks to be in reasonable condition, but pretty filthy (also no surprise).
This one came in at exactly £4.04 plus postage.
Edited by AndyHull
This is such a nice model. Timex couldn't make a bad looking watch between 1968 and 1974 if they tried. (they absolutely could in 1975 and beyond though)
how about an example of said ugly watch from 1975 and beyond!
Well okay it's out of scope for 404 but here are a handful of winners from the 1976 catalog. (I should add, they couldn't make a bad one before 1968 either, but they just didn't swing for the fences with as much variety)
I have never seen 475521 in the metal, but from auction photos it's pretty puzzling what they were reaching for with that dial. If you have one in your collection and can produce a good looking photo, I'm happy to be proven wrong!
Screenshotfrom2024-08-3113-04-15.png.2e4b83f9b2ebb3934182bfa21ae927af.pngScreenshotfrom2024-08-3113-06-41.png.18f47fc6e8ad2d41d4484e44c49fcc8b.png
Edited by mbwatch
My first foray into the 404 club is an accidental one.
My girlfriend's 13 year old daughter picked up this cute little Timex at a thrift store for $1. She'd been wearing it semi-ironically as a fashion statement and I asked if she'd like it to work. "Sure." So I took it home, tried a battery, and it lit right up! So of course I had to clean it up, polish the crystal, and lubricate the stem.
Not bad for $1! I made a little video of it functioning:
Then while searching for an instruction manual for her, I found this:
And this was her response via text:
  • Like 6
  • Haha 2
It is a Camouflaged dial.  Here is one in the waiting to be repaired file.  BTW I do agree that not all the dials or even case styles were interesting.  You can see that Timex put more effort into the Electric and early quartz starting in the late 70's.
Well it worked, because I was sitting here trying to figure out how I could see the carpet through the back of the watch.
  • Haha 7
For 0.99p who (other than every sane person on ebay obviously) could possibly resist.
A non working Newmark with fixed lugs, probably from the late fifties or early sixties.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
