Have this little pocketwatch I want to work on however the case is somewhat rusty. Any ideas on how I would tackle the case?
Thanks in advance
I soaked some of the rusty tools I bought including the tweezers recently in vinegar and a little salt and it got off most of the surface rust.  They were not as bad as that case but I think it worked out well after some #1 and #0000 steel wool.
EDIT: I also neutralized the vinegar with a baking soda/water soak before using the steel wool.
Edited by BlakeL
hi j, i always soak my things like that in wd40 or similar for maybe looking at yours for about 2 or 3 days changing it as necessary and then finishing off with the wire wool, it dont look like you will damage any plating, come back and show us what it comes out like, could be interesting
I am not sure what it's called in english . But something with Oxalic acid in . I used beatroot juice once . Black tea would do also . it will naturalize the rust and make it black . The rust particles will fall off .
Edited by rogart63
Hi Jonathan, you sure have a job on your hands here, are you talking about de-rusting the case before or after you remove the movement?
This is not something I have tackled in horology, but I would have thought there were plenty of rust proprietary rust removing products that would do the job. Once you have pickled the rust out of the case, it would require a lot of power and hand work to get (if possible) a smooth finish on the inside and outside of the case before any playing could be applied.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
