Newbie looking for wisdom
Hi to everyone! My name is Luciano and I'm an electronic engineering student from Argentina (Notice that my first lenguage isn't english). When my great grandfather passed away, he left me a Rado watch, which I have little to non information about.
The watch works, the acrilic crystal is toasted, the strap I presume it's not the original... In the interior of the cover reads the dates: 9-12-82, 3-10-89, 14-4-01, 28-10-02 eje (eje translate to shaft or axle) (date format DD-MM-YY) and the signatures.
The dial reads:
Rado
ANCRE 17 Rubis
de Luxe
Antimagnetic
swiss made
Anyone can tellme anything about the watch? Year of fabrication maybe? It's an original Rado watch?
I searched for a watchmaker in 3 cities near me but I found no one who can service the watch so... It's easy enough for me to do it? and what about change the crystal?
Thanks to all in advanced.
Regards.
_DSC0419.thumb.JPG.59218d474bc92e3216144713f0edaa6c.JPG_DSC0500.thumb.JPG.e4cae5ce150a1eebeb74fc030165e071.JPG_DSC0502.thumb.JPG.418a9e378874fb8547423fb84d138863.JPG
Welcome.
When it comes to the part if one can do it yourself it comes down to the philosofical questions.. Do i have the skillset and do I have the propper tools. If the answer is yes on both of these then for sure you can do it ;)
There are a loot of competent people to guide you through the most of the steps in the process on this forum.
The watch looks to be propper, from somewere around the late 50´s early 60's with a AS 1130 movement inside.
Edited by HSL
swinglish
    • What this extra disk next to the pinion? Thats not part of the assembly
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it worked perfect 🙂 I'm very happy how this method worked out ! 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
