If nothing seems to be broken, I say go for it! I have brought dozens of Timex's back from the dead and they have been well worth the effort. They're simple and robust and a bit of tlc works miracles with them!
I’m not really excited about Timex as a brand. I think it’s the lack of twiddly things called screws, but I’m sure there are guys out there who love them.
I hope I’m not infringing any rules here, but if anyone would like this timex please pm me. I will put your name in a pot and get one of my daughter’s to draw it next Sunday at 5pm. If you are in the Uk, no postage. If you’re overseas I’ll let you know how much postage will be. Just to be clear, I’m giving this watch away. I’ve got a lot of help and knowledge from here and would like to start giving something back every now and again.
Let me know if I’m infringing the rules and I’ll ask for it to be taken down
Keep safe all
King regards
Deggsie
late 70's  Marlin, Taiwanese made model 105.
Thanks JerseyMo I always thought timex was USA? Shall I put your name in the hat?
I appreciate the offer but this one I will pass on.
And the NAME out of the hat is ........... (imagine drum roll........ continuing on to enhance the suspense)......
ANDY HULL
Please pm me with your address and I’ll post it on to you mate.
Kind regards
Deggsie
On 5/17/2020 at 2:11 PM, Deggsie said:
Anyone think this little guy is worth reviving.
The "little guy" in question arrived this morning, thanks @Deggsie so I took a quick look at lunch time.
Nothing major wrong with it so far as I can see, but it needs a click spring, and I'm currently clean out of them.
Here is the offending spring. There should be two teeth on the left hand end, but one is missing.
Here is a comparison with the older arrangement of click and the L shaped hole for the "encheapened" more modern version.
I'll have a dig through my scrap movements this evening, but this is a common failure mode for this mechanism, and I'm pretty certain  a I've robbed the click spring from all of the scrap movements already.
@JerseyMo I may need to purchase a couple more of these to get this going and have one for stock.
Meantime, here for your entertainment are a few more random teardown pictures.
Note today's dial protector is sponsored by KitKat.
This watch is a front loader from 1979 and interestingly this one is made not in Dundee as a lot of the 1970s watches are but rather, this is one of the early Taiwan versions.
One thing they do seem to have improved on this version is the dial tabs, which are fairly substantial compared with quite a few I have seen.
2 hours ago, JerseyMo said:
unfortunately, I'm out of them too!
No worries. I have a few other options.
This for example, is coming in the mail. I may sacrifice its click for the greater good. :D
I also may try fabri-cobling together something from click spring wire, as I have a small pile of that which is not currently doing anything useful. A little creative wire bending may be all that is required. It is only a Timex after all, not a Rolex, so a little creativity is permitted I feel.
@JerseyMo You are of course quite correct, so since it wasn't a suitable donor, I did the decent thing and cleaned and serviced it.
It 'aint no great looker, age hasn't been kind to it (made in 1971),  but at least now it is no longer a biohazard, it keeps time,  and small children don't run away and hide behind the sofa when it enters the room.
The finished article.
All of the grime removed (with the exception of the etched in thumb print on the dial) crystal polished, you can now see through it once more, a quick rub down to remove the polish and hey presto. Perfect... well as perfect as it is ever likely to get.
If patina is your thing, then this should hit the spot. Optional thumbprint (not mine) on the bottom left.
7 hours ago, JerseyMo said:
It was an interesting style.
If the dial wasn't so beat up, then it would be quite a presentable little watch. Style wise, it is very late 60s/early 70s. Have you any idea what sort of strap it would have been on?
I recall they came with a leather strap. You know the expression timing is everything?  well just a month ago I had a replacement dial for that watch.  Gave it away and now I can't even remember to who.  Guess my memory is getting just as patina-ed as that dial :)
I know the feeling... Now where did I put my glasses... One sec while I put on my glasses to go looking form my glass.... err... hang on a second, what was I doing?
On 6/28/2020 at 11:58 PM, Franktimex said:
Hey did you ever get that watch going?
Its top of the to do pile. Just waiting on a click spring (and a rainy afternoon, the garden is top priority at the moment).
    • What you’re saying is that if the entire coil is lifted or tilted either up or down it is due to a slight twist in the spring? Usually next to the stud?  I’ve chased this before and in one instance the spring came out of the stud and I had to reinstall it and secure it in place.  Do you find that the angle (not twist) the spring leaves the stud not only affects how it centers in the regulator pins but also the coil spacing? This could be caused by a distortion in the spring as it grabs and release the pins. I find turning the stud counter clockwise opens the coils 180 degrees away from it. So do I adjust the stud in relation to the regulator pins or to the coil spacing?  I also find that unless I remove the balance from the cock I can’t see the slight distortions in the spring. In my picture the distorted spring looked fine when installed. Do you use Alex’s technique of sliding the regulator arm up and down the curve to find distortions or can you visually see them?
    • So if anybody overrides what i say, listen to them haha. I'm not an expert but i've just been in this boat a dozen times as i used to mess up hairsprings bad, but the good part of that was that i got to learn how to fix them.  What made my life SO much easier was learning how to adjust the hairsprings with the balance installed on a disassembled mainplate, unless it's a very serious problem or on an inner coil you can't get to i would recommend trying this in part because the spring will mostly ALWAYS look flat when the balance wheel is not installed on the cock. Install the balance wheel back in the cock and the cock with the cap jewels in the mainplate, with it installed even the most imperceptible twist will be pretty obvious. Just make sure the balance jewels are also installed. In these movements, if 99% of the time any twist or problems gonna be around the terminal curve, twists often near the stud, especially if you've been removing their awfully designed studs from the balance cock. If there's a reliable way to install those things without introducing a minor twist to them i haven't found it. they're an awful design. INstall the balance on you mainplate WITH your capstones/chatones and look sideways across the balance under magnification. Look for the highest or lowest spot of the now not flat hairspring. 180 degrees from that high or low spot is where your twist will be. You have to be VERY careful with twists as the tiniest over or under twist brings it out of flat. If the area i have to untwist is near the stud i just use a pair of #5 tweezers or some very sharp fine curved tweezers and gently see which way i twist it corrects the twist, then i hold the very fine point of the tweezers on the hairspring and just gently squeeze and check it and see if it started to correct it, then i rinse and repeat. Tiny adjustments is what you want, don't close them all the way, and dont' introduce a flat spot in them. it's just a little nudge by closing the tweezers on it at an angle. .  If the twist is not near the stud, i grasp the hairspring with some very fine curved tweezers as gently as possible while still holding it then i do that same sorta tweezer squeeze with my #5's.
    • Has it got the logo on the crown. I think you're best option is going to be to remove the damaged stem and measure it. Edit Do you have the case reference number.
    • Movement is Omega 1012. I bought this from Cousins:
    • Welcome to the WRT forum.
