Hello Fellas,
I 've been pretty busy these days, but today I managed to finish an Omega Seamaster Deville I've had for awhile. It is a cal. 563 with 17 jewels.  It is in very good condition inside and out and the dissassembly went well..
OK that's was not anything unusual. When I reassembeled the movement however, the cannon and the center wheel had to be held in place while I gently pushed the cannon pinon back in with brass tweezers. I felt that the pressure was not enough and the cannon pinion/center wheel coupling seemed "wiggly" to me. I looked closely under magnification but everything seemed fine--the cannon pinion was sitting properly. Here are the pictures just after I replaced the cannon pinion/center wheel, followed by the hour wheel and the calendar works:
everything else went on very well. As I said, this movement is in pristine condition--it was just dry and needed maintenance.
OK, when I went about setting the watch I immediately noticed a considerable resistance when setting the time. The manual winding mechanism is OK but also seems a little stiff to me. The watch is running well and keeping time so far...
I am receiving a timegrapher soon, and this will be one of the first to go on. I just want to know if I did something wrong when I replaced the cannon pinion. Maybe this is happening because I didn't oil it? Or perhaps it should have been pushed down harder onto the center wheel? I thought I pushed hard enough and didn't want to put too much force.
Any input will be much appreciated.
Regards,
JC
Edited by noirrac1j
It is accepted practise to oil the center wheel post, typically moebius 9504 as this is sold as high friction but practically any grease such as 8200 should work.
Looking at your pics, you have installed the intermediate setting wheel but the cannon-pinion, centre-wheel is not in place.
It is better to install the centre-wheel and cannon pinion first. If the setting wheel is installed, you will have problems when installing the cannon pinion as its unlikely the teeth will 'mesh'. You have a high chance of a) not seating the cannon pinion correctly or b)breaking a teeth off the cannon pinion when you force it against the setting wheel.
Get the escapement running first ..  then comes the rest of the other stuff.
HTH
Anil
Good morning from Scotland Joe.
What a beautiful watch you have there. You've done a really nice job with the service, but I'm a bit worried about the problem you encountered with the cannon pinion. Going by your description it sounds like you have pulled it right out of the centre wheel which shouldn't happen. I think the cannon is seized onto the shaft that should be staked to the centre wheel, and that is why it has pulled out of the wheel with the puller. If that was the case, you would have to have had to use a staking set to drive off the cannon from the shaft, then also use the staking set to stake the centre wheel back on the shaft.
I hope I am wrong about the above, but I think it is the reason the watch is so hard to set. If the cannon is still seized, you are possibly trying to turn the shaft in the centre wheel.
Please tell me I've got this wrong Joe, or it's a complete strip down again. :(
Edited by Geo
I presume it is the centre wheel that came adrift. With clocks if the wheels are not aligned correctly or they have the slightest twist they tend to bind.
What ever it is it is time to strip the centre wheel etc and double check absolutely everything. If the cannon is binding you should see some sort of scoring etc.
That's a lovely watch and well worth the time spent on it - hope you\re successful in sorting the winding out.
Might be helpful if it is the centre wheel or cannon fault two eBay sales. Item numbers as follows;
No.   111137314816
No.   291354762786
Thank you Anilv, Geo Clockboy and Will fly for responding. This is why I should have waited until I got response before reassembling! You guys are very good, and you help me become better. Anil, I do think you've identified the problem and now I recall the ordered-step that has lead to this problem. When I took the cannon pinion off with the puller,the intermediate wheel had already been removed, so I think it came off the way it should: The cannon pinion is on the bottom plate side and when I pulled it off the center wheel on the other side was free to come off.
When I reassembled however--and this is where Anil's observation immediately struck a chord--I had already reinstalled the intermediate wheel and, it did give resistance to the proper seating of the cannon pinion. I applied enough pressure so that it became semi-seated, but I should have know that the cannon pinion/center wheel "wiggle" would come back to haunt me if I left it as-is.
I can't leave the watch this way, even if its running OK (which it is). I am going to have to take the watch apart and do a reassembly--this time paying very close attention to that cannon pinion/center wheel coupling. I have learned with this experience not to be too hasty to finish.
Thank you for the input. I'll give an update soon.
JC
Excellent Joe, going by your description I thought that you had dislodged the wheel from the spindle. It should be an an easy fix Joe, and I look forward to your next report.
Good call Anil! :)
This is an excellent thread!
And one that all newbees to watch repair, like me, should read until they understand what went wrong here.
I applaud you for sharing this with us JC, and never feel silly or ashamed for exposing your mistakes, as we can all learn very important lessons from them, and thus you become our teacher.
The way I have been instructed to assemble is in the following order:
Gear Train and Mainspring
Canon Pinion
Keyless Work
Motion Work
Is this how everyone else is doing it?
Canon Pinion
Keyless Work
Motion Work
It works for me. :)
Thank you everbody for the suggestions. Anil you did a great job diagnosing the problem-- Been there done that? Oh yes, experience is the best teacher! I took the watch apart and this time I secured the cannon pinion/center wheel before putting the intermediate wheel in and it worked. The winding is smoother and I can set the time without needing latex for uhm.....protection.  I am always afraid that redoing a watch will result in something going terribly wrong that will overshadow the original problem, but things went smoothly. I hope this experience helps someone else from doing the same thing!
Hopefully doing it right the 2nd time
Looks better than before
And now on the wrist
Regards,
JC
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
