How to oil this autowind?
Lc130
Hi All,
This is an AS 1916 and I'm a beginner.  Should the circled areas be oiled?  I only have Moebius 8000.  Below is the same plate with with the wheel and clutch(?) installed.
Thank you
Charlie
IMG_4637_LI.thumb.jpg.7bdf6a5be60e0ed2efd1dd6dd4a3b970.jpg1217165093_IMG_4577(1).thumb.JPG.2035f848191ffbfce1473a9afacf1507.JPG
Hi unless specified otherwise all moving parts bearings and posts carrying wheels and clicks require librication, the part and its function , friction and load require different oils and greases. The two attached publications will give you guidence on which oils/greases to apply and where.
Moebius Oil_Chart.pdf BTI-The_Practical_Lubrication_of_Clocks_and_Watches (1).pdf
Very helpful, thanks!  I did look through the BHI.  It said to follow the manufacturers tech info for autowinders.
A follow lube question:  I don't have a MS winder.  I have been removing the barrel lid and running the barrel with spring inside through the washing process.  I then add a small dab of Moebius 8200 to the top of the unwound spring.  Would that be optimal given my ability and lack of winder?
Thanks for the advice
Charlie
Hi Charlie  Due to the lack of your resources ,  in that case a little oil that has been applied will do no harm, better that than running the spring dry which would lead eventually to a breakage.    By the way the spring can removed by hand and re fitted the same way. If done carefully and with understanding that rough handling the spring can be damaged.
Ugh!  I didn't realize that a dry spring could break.  I'll have to practice reinstalling a MS by hand.  In the past I couldn't do it.  Very helpful info.  Thank you.
BTW, I have three sets of MS winders from ebay.  Most have the hooks sheared off.  I can't bring myself to buy a new bergeon set.
Fitting them by hand is absolutely fine and a skill I recommend practicing. You are unlikely to snap a white metal alloy spring. Pay attention to to the orientation of the spring if it is a modern “S profile” as part of the spring naturally rests inside out. Focus on the inner coils which will normally turn clockwise from the centre when looking into the barrel from the cap side.
Add a few small drops of oil to soak into the spring. And a tiny amount at the bearings when the cap is snapped on.
I guess one always can break all kind off springs and by different reasons.
I still mostly use manual oilers even if I got a bunch of automatic ones.
When looking at your winder assembly I hope you flipped the click so you haven't tried to fit it as it is in your picture.
I would invest in Lubricants and practice cleaning of the watch movement as a first step since that will be the most important steps regardless of what you do in the feature in Horology.
So even if you got only Moebius 8000 you could always practice lubricate your movement and later on improve the status of it.
But now let's se how you could do for now. I taken pictures from the teardown too so you can put it together just by reversing th sequence.
First we have to get the oscillating weight off by loosening the lock. Just loosen the screw so you can move the lock to the side.
With the lock bolt loose lift the oscillating weight away. To get the autowinder away first screw off the three screws it is fastened with.
You could put a extremly small drop in the hole shown in the picture or on the pinion of the gear.
Later on when you put the winder back together lubricate at theese two spots. Just a small drop.
There are nice pictures shoving the amount you should use  in those documents you were presented earlier in this thread .
The same goes here lubricate in these three spots, but not when you take the winding assemly apart, just when you cleaned it and put it all together.
Always lubricate the surfaces where metal goes against metal.
The lever you call "Clutch" actually is like the click by the crown wheel, since you don't have any reversing wheel in this winder this click will prevent the oscillator to wind the mainspring the wrong way. So it is more like a break.
In your picture it is flipped the wrong way again.
After lubricating where metal parts meet eatch other just put the bridge back and go the reverse way in this picture series.
Now you can lubricate in phe previously shown positions.
Always try to document by photographing everything before and after you make an egagement on the movement.
Hope this helps..
Edited by HSL
HSL
Many thanks for the help.  Yes, my picture has the click the wrong way.
Do you assemble the autowind first and then fix it to the movement?  I've started by fixing just the bottom plate to the movement and then building it.
Thank you
Yes I first build the autowinder assembly.
As you can see me and other people use Rodico not only to clean the movement from stubborn dust but also to fix parts into place while assembling, here the Rodico holds the ratchet driving wheel into place while putting the other parts and springs into place. Otherwise the wheel would with high probability fly away together with the springs.
The bridge then has guide pins which makes it easier to put it in place, little fiddly but easier in the way presented in the pictures..
Edited by HSL
    • $12.50 + $6.00 shipping I do enjoy collecting ladies watches.
    • What voltage are you feeding it?
    • Maybe you had a bad one H, the cheap blue one i use has been fine for nearly 3 years now. It demags enough to stop the tiniest of screws sticking to the carbon steel tweezers i use. If it were to fail at some point in the future i very  probably would go up a level of device just because.
    • Lot of “industrial “ de magnifiers on Aliexpress  https://www.aliexpress.com/item/1005004699640024.html?src=google&src=google&albch=shopping&acnt=708-803-3821&slnk=&plac=&mtctp=&albbt=Google_7_shopping&albagn=888888&isSmbAutoCall=false&needSmbHouyi=false&albcp=17858129175&albag=&trgt=&crea=en1005004699640024&netw=x&device=c&albpg=&albpd=en1005004699640024&gad_source=1&gclid=CjwKCAjwo6GyBhBwEiwAzQTmcxIEVpMt1vFIKQyfjVwT95zrBsOi5dt-GgFOmLamBcMcu4tO7CfaaxoChnEQAvD_BwE&gclsrc=aw.ds&aff_fcid=b7140f118e144db7876d074872aec9cb-1716029308364-08531-UneMJZVf&aff_fsk=UneMJZVf&aff_platform=aaf&sk=UneMJZVf&aff_trace_key=b7140f118e144db7876d074872aec9cb-1716029308364-08531-UneMJZVf&terminal_id=6b7c60e41b044cb39d1431f62cda0958&afSmartRedirect=y   a hard drive wiper/degauser would also be worth looking at.   Tom
    • Unfortunately yes! Magnetism can wreak havoc on a mechanical watch movement if the balance hairspring becomes magnetised. The cheap blue Chinese demagnetise-rs are useless if you feed them the wrong voltage (> 110 V), and even so, they don't work very well. The one I got when I was new worked so poorly that it drove me nuts. Eventually, I was lucky to get a Greiner Magnomatic for a little money. It's an amazing tool that can be trusted to do its job perfectly in seconds. A new one comes with a price tag of  £885 excluding tax and shipping, and if you think that's a bit steep (I believe most of us would) and can't find a used one I'd go with @Jon's recommendation.
