HELLO FROM SOCAL
melav8r
Hello Everyone,
Been a watch lover as far back as I can remember, since at least 5 years old!
I have owned Timex', Citizens and Seikos, early on and later got into swiss aviation themed watches, Glysine, Breitling and even a Rolex GMT in my young adulthood.
Over the last 5 years the bug bit hard and, after going down a deep rabbit hole, I now have a collection of close to 50 watches, the majority being vintage automatic Seiko Divers but now starting to appreciate the older Seiko dress watches too.
Around the same time I started fiddling around with watches to source the ETA 28xx movements which I've used to build a couple custom watches.
I'm considering taking some lessons to further my skill set and service my own movements.  I modest watch tool collection and have un-cased and re-cased movements, changed batteries, replaced crystals, bezels, dials and hands, and tore into the keyless works, mostly to swap out the 3-position set bridge, on no-date watches, to a 2-position set bridge.
I've recently become aware of and started watching Mark's WRC videos.  Great videos!
cheers,
Mel
    • If you're seeking advice for your "Harvard GSD" MArch II application essays, I'd recommend taking a thoughtful approach. Reflect deeply on your experiences, passions, and goals, and tailor your essays to showcase your unique perspective and potential contributions to the program. As for resources, I recently stumbled upon a gret platform for essays, and I must say, it's been quite helpful. Their selection of pre-written essays covers a wide range of topics, and their professional writers can also assist with custom essays tailored to your specific needs. Check out their offerings here: https://essaypro.com/essays-for-sale. Remember, authenticity is key in your application essays. Good luck!
    • For clarity and ease of testing, I redid that diagram, flipping the circuit to match the layout of the physical watch.
    • Hello, Thanks for the reply. The old jewel will get pushed out from the "outside" which is the dial side. The new jewel will get pressed in from the inside (shown below) which is the movement side, correct?     And the old jewel and spring will get pushed from the is the "outside" which is the dial side. Thank you very much for the information. I will take out the KIF spring and save it. Will update when the new jewel is in place!   Regards, Joe
    • It's a little circlip style retaining clip to keep the pinion from riding up out of position.
