Chronograph hand loose
The centre sweeping hand has become loose on my watch. It’s a Chinese clone movement and there are no spares available unfortunately.
Where the hand attaches to the post is nice and tight. The problem is with the construction of the hand itself. I’m sure you guys know how these are put together but for anyone that doesn’t know, the hand is made of two parts the post and the part that rotates around the dial.
Looks like these two parts are just pressed together. This connection between the two parts has become loose, so when you reset the hand it won’t return to 12 (sometimes a few ticks off, sometimes 1 etc).
Ive tried using super glue and two part epoxy to hold the parts together but it hasn’t been successful.
Does anyone have any suggestions?
Thanks.
so if these hands were staked (riveted) together and now that part is loose. That indicates to me the part is damaged and the hole is probably worn so too big for the post part (I may be completely wrong here?). If it is damaged/worn is it possible to stake them together again?
Thank you for helping, I’m learning all the time here.
In a lot of cases re-staking is possible. If you don't have a staking set a crude method with thumbtack I've tried before worked for me:
Fit the tube back into the hole and have it stand upright, and then tap the tip of the thumbtack into the hole. Make sure to start with light taps and check progress under magnification as to ensure you don't split the tube. You just want a bit of expansion of the tube where it fits into the hand. Also make sure to do it on a hard surface so it doesn't absorb any of the impact and have the tube driven into it.
Also consider filing the tip of the thumbtack to put some facets to it. This will make the rivet irregular and stands to have less of a chance of slippage at reset than a perfectly round rivet. Although the one time I tried the thumbtack I didn't bother with this and the subject watch hasn't given me any problems yet.
Edited by CaptCalvin
I do actually have a K&D staking set (I have a bit of an obsession collecting tools), not sure if I have all the correct parts to do this repair though. Unfortunately I  have no idea how to perform this task though. I’ve checked YouTube and can’t find anyone doing this. Would love to give it a go though if you guys have the time to run me through it :-)
here is a video of what is happening
So using the thumbtack method I could keep the hand tight  in the collet (as seen in the video)and knock the tack from the top? This would force the Pipe part of the hand to expand slightly inside, hopefully gripping the hand.
is the method the same with a staking set? Knock into it from the top?
Edited by AP1875
Does the tube have a lip around it to support the hand as in the first picture or just a straight tube with the top turned down to fit into the hand? The straight tube type would be a little more challenging.
Do you know how to use a staking set? I dont have a staking set on hand at the moment but I would start with the sharper punches and progressively move through blunter and blunter punches until the rivet is nicely rounded and peened over.
A big issue with staking or restaking tubes like this is distortion of the tube itself. I've made up stumps with a hole diameter ever so slightly bigger than the tube, depth ever so slightly less than the length, so I can rerivett the darn thing without bending or otherwise deforming it. They can be a real bear.
Ok so it looks like the hand in question is the type that’s ‘easier’ to work with
5DC677FD-EEF4-439F-826A-401922E42A21.thumb.jpeg.beba68878d963cbd2d484ece2371ffea.jpeg3D0E7706-6E3E-4A01-8DEC-EA90123C6F7C.thumb.jpeg.235272c3e564f119390118ba576424f4.jpeg
only issue now is I don’t really know what the procedure is.
This is the tool I have, it came with a K&D box with quite a few bits. I was told I’d need a staking set at some point so hopefully this works out. Any direction greatly appreciated.
Reason why these are easier to fix is because they can simply be set into a hole in the staking contraption and not fall through.
1) Find the smallest hole on the platform that the tube will fit in.
2) Loosen knob behind contraption.
3) Insert centering punch (sharpest pointed).
4) Rotate platform and drive centering punch into selected hole.
5) Tighten knob. This ensures whatever punch you're going to use is aligned with hole.
6) Insert tube into hole and fit hand on the tube.
7) You're going to have to judge for yourself which punches to use here. Start with the sharper punches and work your way towards blunter punches. The idea here is you want to expand the tube so that it grips the hand, and you'll also want the top of the tube to curl outwards and over. Sharper punches are more efficient at the expanding, and blunter punches will do the curling. Don't get aggressive with the sharp punches and go too deep and split the tube.
But really it would be nice if a someone with actual experience chimes in. I haven't yet touched a staking set (poor college kid). This is just a procedure I've thought up in my head with knowledge accumulated through books and internet. Try it if it makes sense to you haha. :startle:
16 minutes ago, Hondadoug said:
I think in this case a small flat punch is all that is needed to flatten the rolled portion and restore the crimp. Don’t over think this  it is just a very simple basic repair. Make sure your anvil supports the lower flange .
Starting with a flat punch would be smart actually. Chances are that's all you need. And if it doesn't work then you can try the pointed punches. Flat punches are more forgiving so not a lot of harm done as opposed to trying the pointed punches first thing and whacking it a bit too hard.
Ok so I put the hand in the base like this?
I will then line up the base with a stake, so a flat stake can sit directly on the hand (I will use some plastic wrap to protect it)
the idea is to use the force from the stake on the top of the hand and hopefully it will cause it to expand gripping the hand.
Did I understand that correctly? I just want to make sure I’m doing this correctly because it looks like I’ll only get one shot at it. Thanks
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
    • Hello and welcome to the forum Dan. Used to know Middlesboro quite well, that was twenty years plus ago. Attached a little reading to get you started. TZIllustratedGlossary.pdf
