Arrived this morning (must update ebay)
Looks even better in the metal.
Chromed base metal case. Spotless acrylic crystal and nice dial. Unusual, vintage leather rally strap.
How do I remove this odd caseback? Listing said not working but I wound it up and after an hour its still going. Want to take a look at the condition of the movement.
That looks suspiciously like a Buler case back which masquerades as a Panerai case back. If it is a Panerai there is a special opener though you could get lucky with a sticky ball. If it is like the Buler it pops off with the case opening knife. Have a close look around where the case back meets the case.
Cheers,
Vic
Cheers,
Vic
Hi. Looks like it pops off. Took a dry stiff toothbrush to it and dislodged a bunch of DNA revealing a slot.
Will pop it off after lunch and take a look.
Still running and keeping time well.
Hmm. Probably cost a small fortune.
How about I cover it in clingfilm (saranwrap) and use some of that metal putty that you have to knead to activate.
I could then press it onto the clingfilm and make it take the shape of the case.
Before this I will wait and see what the seller confirms.
Thanks bobm12 & Vich
Edited by ro63rto
I like your thinking with the metal putty.
There is also the M12 nut (or bigger) and super glue trick if the putty fails you.
    • Hi All, I’m having a hard time finding a balance assembly or even a working donor movement for a Gruen 330.  Any leads appreciated.   Gruen doesn’t stamp the caliber number of the movement but lust in the case back.
    • Why do you think this is Fontainemelon ?  The balance staff you will need to source separately.  But first it's important to accurately identify what you have there. Research Ebauches Sa, see who was in group, to find the brand that made this movement.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
