How to open Helbros (France) case
There is no lip on the back case, don't think it pries off.  Note the watch back stands proud of the case by 1/8 of inch or so.
I pulled the crystal, and have put quite a bit of pressure on the stem - don't think it is split stem.  But, the dial is way to big too go out the back.
I bought a bezel removal tool, it does not move the face bezel at all.
Any ideas?   Thanks!
Edited by gaseff
typo
It does. Just go around it with a japanese type caseback tool, its tip may need to be sharpened a little. There are also lever type tools but doesn't look like it's needed for this.
I recommend againat using razor blades, very unsafe and no way to exert and control force without making some of handle. If a caseback knife is not available an x-type knife can work as well.
Edited by jdm
Thanks for advice Jdm, that explains why I only got one finger left.
  • Haha 2
  • Sad 1
    • No matter what I did, I could not get the amplitude more than 240 deg. At least there is 0.2 beat error and minus 1-2 s/d.  So, probably not the happy end I would have hoped for, but still I think the watch turned out quite nice. You be the judge of that. Thank you everyone for your help!
    • its used to lengthen or shorten the suspension spring from the front f the clock dial, this in turn will give regulation to the clock. Try inserting a pocket watch key or even better the double ended key for the clock into the small aperture on the dial at the top and turning it, you will see the suspension block either raise or lower. If it raises the clock will run faster if it lowers the clock will run slower
    • Grateful for info regarding the nature & function of the horizontal cog and the unit it's on top of in the picture. It meshes with a vertical cog (enclosed in the unit) on the arbour which is supported at its other end by the back plate of the dial unit to which it is not quite perpendicular...
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
