Old clocks for Eco warriors?
Tmuir
I'm sure where-ever you are the news is filled with climate change news articles and meeting the Paris Agreement targets and similar new articles, and it has been causing a little thought in the back of my brain to keep ticking over.
Should we be mentioning or even promoting the benefits to the climate in buying a good quality serviced vintage or antique clock?
No plastic in the clock, can be serviced and outlast the owners if looked after and probably has a wooden case so is even stores a little carbon, its wind up so no batteries to worry about.
The same can be said for a good quality vintage watch.
I'm only mentioning this half is jest but it could be mentioned as another positive reason to invest in a vintage clock.
I've only ever owned 1 quartz clock and that was something I was given as a wedding present that wasn't on the gift list, I was very pleased when a couple of years later the hook it was on gave way and the clock smashed on the ground which gave me my excuse to tell my wife we needed a good English Fusee wall clock. :D
Hmmmmm....carbon emissions...have you ever  looked at a graph  of carbon emissions  since 1750?
      Conversely have you ever looked  at a graph  of human  population  since  1750?
      The curves are eerily  similar. Could  it be that  these  emissions  are driving the population  up? More carbon dioxide, more photosynthesis ,More food, More people. Less carbon dioxide,less photosynthesis, Less food, Less people.
        The Earth's  population  was relatively  flat until  we started  burning  coal. Are we polluting  the  Earth, or fertilizing  it?
Increasing industrialization (resulting in increasing emissions) has allowed much more productive agriculture, which has allowed us to support ever growing populations
   the plastic, quartz clocks  burn good too.  vin
There is a strange paradox with plastic. Yes, it is completely non-biodegradable, but by the same token, it locks up carbon pretty much forever. You don't want to be burning oil, coal or natural gas to make energy, but making plastic is another matter.
The issue with plastics is more to do with the fact that we re-cycle far too little of it, and thus our environment is heavily contaminated with it.
The same is true of pretty much all of the "ingredients" in our consumer goods. They are typically produced to a price, and engineered to fail. This is of course the madness of infinite growth Laissez-faire Capitalsim. The trouble starts when you try to address this, as the moment you challenge the near religious fervor that surrounds capitalism, people scream nonsense about Communism, and "you must be some kind of communist",  as if it is the only alternative. Leave aside the 'isms' and address environmental matters in a more scientific manner and you will find solutions.
As to using a mechanical watch or clock. They are actually a brilliant example of good engineering. A well built, well maintained mechanical timepiece will keep going pretty much forever, and use zero additional carbon over its lifetime.
Compare this with an "Apple Watch *"  These products are designed with a fixed lifespan. Generally they are not maintainable in any meaningful sense, and their use of energy (and thus carbon) is many orders of magnitude higher than a comparable mechanical watch.
Should we therefore be encouraging everyone to wear a mechanical watch?
Of course, after all I have cornered the market in sub £4.04 mechanical timepieces, and my Capitalist senses see a boom in the market if we do. I'll be rich I tell you  $$$ RICH $$$  :D
(*other hideously over hyped and over priced brands are available)
Edited by AndyHull
Yes, agreed plastics are a problem, while at the same time being a solutions to other problems.Hence the paradox.But I see the same thing with carbon emissions.We are releasing carbon that has been locked up in the earth for eons .This carbon fuels life.Human life.Of course this is only my theory, which all are welcome to refute.If I am right ,a serious reduction in carbon emissions will result in a reduction in food production.which will result in famine .As for mechanical watches.given proper service they can last almost as long as that milk jug out in the middle of the Atlantic.
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
    • Why cut the paper, cut a square around the image and grind to it.
    • I did try that last time Rich , i traced the image from the Bestfit book which is the actual size. But its more difficut to cut the shape from paper than it is to grind the steel to shape. This way is pretty easy and the final shaping is done when fitting the part. There are a couple of things i will do differently next time, clamping the 2 pieces together with a drill press will help to hold while scribing the shape in. This was a bit tricky having only one hole, if using the pins and cork the drill size needs to match the pin diameter so there is no movement at all from the template. This movement hasn't finished frying me yet, damaged thread in the plate crown wheel hole and two rubbed in cracked jewels, thats gonna be much more fun.
    • 👍 Whats not to follow OH ?  You're every inch a pro and a true gent, i always enjoy reading your answers even some of the clock stuff that i dont have a clue about.
