If I'm not mistaken that's for an air line to a compressor. High volume shops will skip the pump handle and hook right into their compressed air which is inevitably there already.
Looks like a push-release fitting, on these the line (hard plastic) pushes in and is sealed. To remove you push and hold in the bit visible in the photo, the line comes right out. If you don't press that in the line is next to impossible to remove and and you get what's seen in the photo.
