What Is The Best Adhesive For Hour Marker
DJT2
When it happened to me I used epoxy adhesive a pin and a loupe. If you look at one of my early posts I actually put the Roman numeral 11 (XI) around the wrong way so the watch finished up with 2, 9 o,clock,s  :D
Edited by clockboy
Lol to be fair there are 2 x 9 o'clock in a day
I just use the smallest drop of "GS Crystal Hypo Cement Watch Crystal Glue".
I've got some of this on order so when I can find a new marker I'll give it a go. Thanks
Use an oiler to carefully apply a tiny drop on the back of the marker then carefully place it on the dial. Don't place the glue on the dial first, as you my get a small string of the glue across the dial as you draw the oiler away. If you gently place the marker vertically on a piece of Rodico, you'll be able to apply the glue to the back quite easily. Doing it this way it is still easy to pick it up with tweezers without having to get into contortions to place it accurately. A good thing about thing about using this glue, is any excess can be cleaned off with alcohol.
  • 3 months later...
After Geo's excellent recommendations, I now use gs hypo cement for most things watch related. Eg date wheel overlays, hour markers etc. Got mine off amazon uk
Thank you Geo. I will heed your advise. DJT2, how is R2D2?  :D  Sorry DJT2. I couldn't resist. But I'm sure that wasn't the first time you've heard that comment. However, thank you for your advise. I'm off to Amazon.com USA.
I try to avoid applying any adhesive to the front of the dial, most hour markers have posts that can be cemented from the back of the dial, of course this does usually mean the extra work of removing the hands and movement, but it's just too easy to ruin a dial with an errand twitch when gluing the front.
  • 2 months later...
I have a bottle of clear nail polish on the bench for this purpose. Strings of glue from GS Hypo is too much to handle and I use GS Hypo more for glueing rhinestones. Epoxy is too troublesome for such small job, I usually used it for watch glass.
All good suggestions . Easy to see that we've all been in this situation. I've used the cement that Geo suggests and I have also used loc-tite , the stuff you use on the stem and crown . I usualy put a drop on a flat piece of cardboard and smear it around so it's a thinner layer , then use a small bit of rodico on a pegwood or toothpick to pick up the index or whatever I'm attaching , transfer some of the adhesive from the cardboard to the index then place it on the dial . Usually a 1 shot deal . Hold down the index with a small screwdriver so i can remove the rodico/pegwood . After it dries you can use a sharp pegwood to clean the edge of the index if necessary...usually not.
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
