hi guys, i am in the process of organising my spare movements into a workable index, fed up with knowing i have a part but where is it, by the time its found would have been quicker to order it, so this is the filing systempost-618-0-56568000-1421251855_thumb.jpgi have also set up a web site but i am unsure about this sites rules so i won't list it here you may have to p.m. me. i'm sure someone will let me know. another reason for this is that when i first started on the watch repair road although only about 4 years ago was that if i needed a part to fix a £2 watch was say £5 plus the p&p of say £4 this seemed very costly for a hobby and not know very much this may or may not even get the watch running so wouldn't it be nice to be able to get bits cheaper.this is how i would like it to be for members of this site, all parts are £1 except mainsprings £2 and balance £3 the postage will be at about cost so uk could be second class post but even for a heap of bits will only be 70p, i would even prefer to have a fair exchange of a spare movement of yours that i haven't got this will increase the stock pool for all members to dip into. at the moment i have 75 movements listed from 20 manufacturers and i add to this almost every day. please give me your thoughts on this
hi guys, this is the address, [//forum rules please regarding links to your website//].com the site is in progress and i will have to change it at some time but i was more concerned with getting it up and running but you should be able to navigate and get to where you want to go, any suggestions would be welcome, if you need any parts make sure you let me know your from this site so as i know how to treat your order
  • Similar Content
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it worked perfect 🙂 I'm very happy how this method worked out ! 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
