EB 8371-67 endshake.
Im in the process of overhauling a lucerne chronograph running the EB 8371-67 single jewel movement.  It is a very rudimentary,  pin pallet movement with a simple chronograph function. The problem im having is the balance has significant endshake. The pivots on the balance are intact.  The watch only runs in the dial down position but is running very fast. If you turn it dial up,  it immediately stalls. I do not own a staking  set so I have no way of running the lower jewel setting in deeper. The balance "jewels" on this movement aren't actually jewels,  but are polished metal caps that ride under a standard novodiac shock spring. Does anyone have experience with these types of parts? Do they wear out,  are the balance pivots worn out,  both? What are my options? Thank you for any advice.
I would first look at the tips of the balance staff with strong magnification. I would not be surprised if one of the balance pivots it snapped off. If not then the lower jewel setting will have to be moved in a touch. However without a jeweling tool or a staking tool with micro adjustment attachment then adjustment will be problematic to say the least. The tiniest of movements make a big difference.
  • Thanks 2
I guess my question now is, Does anyone have the tools, experience and desire to perform this for me? I'm willing to pay for the service if a reasonable price can be negotiated. That said, should I hunt for a parts donor and try that if it's cheaper? This isn't hugely important to me, but I've invested a lot of time in this watch and I'd like to see it though. thanks again
4 hours ago, FLwatchguy73 said:
Come to think of it, Mark has never addressed an issue of this type on his Watch Repair YouTube Channel. I'd gladly volunteer my movement for the lesson. If it can be negotiated and there is an interest, I'm very willing! :thumbsu:
I have experience with these single jewel movements. I have had a few of these french branded watches. Lucerne wolbrook rego chateau and cimier. These movements were not really made to be serviced. Anything can be serviced but this movement will be a real challenge. I suspect a broken pivot on the staff. If thats the case you will never get a new staff for it so you will need someone who can make one on a lathe.
Both pivots are intact, I checked under strong magnification. That does not mean that they aren't worn, especially considering the "jewels" are actually a polished metal cap. Metal on metal wear is possible, but I have no way of confirming this other than what I'm able to observe.
Anytime a movement stops in any position its due to a pivot problem, wether it be bent worn pivots causing too much shake, and broken or cracked jewels (but not in your case) It could also be the pallet, too much shake in the pallet can cause the safety roller to touch the impulse pin causing it to stop.
    • I used to just remove the stem pop the movement in its case then put the stem back in check everything then back on the timer.
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean. Something like this, but tbh its better to just learn to do with your fingers.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
