heeeelp please!!!!!??
zamoume
hii guys , i really need ur help pleaase ..i have a a lotus quartz watch 15301/2 multifunction ..i I completely disassembled it and i have i problem with repairing it(reasembly)
plzzz anyone can help text me on whatsapp i will show him the prob by pics . btw i didnt find any video to follow for my watch
thanks alloot guys
+212665958429
insta:ahmed_zamoume
Joined here in distress after searching, then expecting people to chat you up personally to fix a quartz watch? The correct approach would be identifying the module used an buying it new, likely about 10 USD.
thanks alloot guys
+212665958429
insta:ahmed_zamoume
I would be glad to help but its best if you submit your photos on here so anyone in the community can share their thoughts on your issue.
I agree with Chopin and jdm, With insufficient data we cannot work miracles.  as stated we need photographs of the rear of the watch and backplate  also the front plate and any writing that is on the back plate to be able to identify it. Depending on the state its in now may be a replacement movement will be in order and without the data we cannot proceed.
    • Usually the coiled spring contacts the piezo sounder and the finger spring is the ground.
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
