First go with a Kommandirskie
Just started on my first attempt to restore a Wostok Kommandirskie. Winding stem broken but crown still around with remaining stem in the crown.
The 2414 movement appears to be in surprisingly good condition and the casing should be ok with a bit of cleaning and polishing.
But...when searching for a winding stem all that show up seems to be kind of ”integrated” stem and crown.
Are these generic to fit all kinds of casings?
And how does these screw-down crowns work? I suppose there must be space for the stem to move in when the crown is screwed tight?
Grateful for some advice from some of the guys with a special interest in these russian wonders!
It's kind of a slip  clutch set up.and the length is determined  by the case.for the  most part all komandirskie cases are interchangeable. You can order new stems directly  from meranom. Fixing old ones is not practical.
Edited by yankeedog
So the stem moves in/out inside the crown with a slip/lock function to allow for the screw down action? Makes sense.
I checked briefly the supplier you mentioned but couldn’t find any stems. Maybe I need to contact directly.
And there’s an overwhelming number of styles and casings still in production.
Any idea what mine could be called? From my point of view it looks like one of the more common with its 2-coloured bezel dots.
If the supplier is easy to communicate with, I guess I can send him a photo?
Are they easy to deal with, from your experience?
go to meranom.com, click on shop, click on komandirskie classic parts, you will see it. it is listed as a crown.it will set you back a whole $3.00 US..It ought to fit, but even if it does not. it's not a loss to cry over.I do believe they will answer inquiries. for not a lot of money you can get a new case
Edited by yankeedog
I believe  the komandirskie  stem is of the same type as the amphibia.  Is has a loose and wobbly  feeling  about it.it is normal  for the type..supposed  to stop shock  from being transferred  to the movement.  To me that sounds like hype.
Edited by yankeedog
There is alot of mechanical  incest in the amphibia / komandirskie  lines ..biggest  differences are stainless vs plated case on komandirskie..thicker  crystal  / case back and fatter gaskets on amphibia. All dials and movements  will  pretty  much  swap  out provided you have a back that  will  accommodate  a rotor on an automatic and the correct retainer ring and stem. I am pretty  sure that all komandirskie  with 24xx movement  use the same stem while amphibia  stems vary in length  according  to case type. I may be in error  of course  .but this is my understanding  . The 22xx are another  animal  entirely.  The dials will not interchange with the 24xx and the stems have a different  business  end and do not interchange either.you can however  retrofit a 22xx into a 24xx case provided  you have correct stem and ring. Case crown threads being the same. Earlier  komandirskie  did not have a threaded crown..I think they got them when the transition  from 22xx to 24xx happened.
Edited by yankeedog
Thanks for the added discussion. I mailed Meranom and had a quick response that the offered stem likely work but no guararantees. Sounds reasonable enough to take the chance for 3$ :)
Beginning to realize that these watches are both simple and complex at the same time. But it’s fun that the Vostok factory is still producing in spite of decades of turmoil. And the brand characteristics is maintained.
I will start to service my 2414 movement, order a new stem and try to make a wearable watch out of it.
19 hours ago, Ruairidh said:
That would be a sensible idea as although a very rugged movement the one found in the amphibia has a habit of being very inaccurate.
I am not  too crazy about the 24xx series. I think the 22xx series  is simpler more accurate  and more robust. It is very  much like  their  2809 but smaller  and built  to looser specs.
Hi again...
Got started on servicing the 2414 and immediately ran into a new problem.
Turns out the centre wheel shaft, driven by the main spring barrel has come loose from its wheel and no force is being transitted further to the wheel train. The wheel still sits securely on the shaft but spins freely.
Never experienced this problem in any movement before.
The attached photo shows the splines like arrangement that I presume is supposed to ”bite” into the wheel brass to secure it.
Would the appropriate thing to do to use my staking set on those shaft splines like teeth and hammer away (well not really...) to secure the wheel?
Think I managed to tighten the grip on the wheel with some light tapping in the staking set. I guess I will see if it holds up...
There seems to be a few people offering scrap movements for spares on ebay but not at all as many as one can find with some of the more generic ones.
Meranom was helpful and replied back quickly on my crown/stem enquiry. But apparently he doesn’t accept orders below an amount that makes the 3$ plus postage, customs fee etc.spin off to a lot more than I paid for the watch to start with.
Have a box full of Vostok parts if you need anything bsoderling. I need a crown for a Vostok swing lug i am about to service . Have a few contacts that could have that . Maybe they have a crown for you watch also . I  bought  parts from Ukraina . They sent it from Holland . So was inside EU . I think they have crown. I shall see if i can find it .
42 minutes ago, vext01 said:
Sorry to hijack the thread, but has anyone ever encountered a service manual for these Vostok movements? Even if they are in Russian language, even the diagrams would be of help.
Thanks
Strictly speaking you should start a new thread, however this link may help, not strictly a service manual, but in some ways every bit as good.
https://forums.watchuseek.com/f54/vostok-caliber-2414-service-notes-very-long-many-pics-226237.html
.. and of course, Mark's video is an excellent resource too.
A search of Watchrepairtalk will give you more useful tips.
Oops. My apologies. Next time I will.
That is indeed very good! Thanks for the link!
Until now I've been using youtube videos, but I find it's also nice to have the service manual on-hand. I've been unable to find any for vostok movements.
There are some manuals available, but there doesn't seem to be one source for everything. A bunch of useful stuff is here -> https://forums.watchuseek.com/sitemap/f-54.html
If you want USER manuals you could try here -> https://www.russian-watches.info/russian-watches-user-manuals/
.. but who ever needs a USER manual :D
Finally, a bunch of Russian watch sites... https://forums.watchuseek.com/f54/russian-watch-links-interest-13891.html
Google translate may be required unless your Russian language skills are up to the task.
Edited by AndyHull
Hi all,
Just wanted to wrap this one up and show where it ended.
Finally decided to purchase the stem/crown from ebay seller ”bestrus” who was able to point me towards the correct item for the somewhat older style casing I have. He even threw in an extra free dial that looks ok and may come handy at some point.
Only the yellow crown available, these are apparently getting quite rare.
Rivetting the wheel onto the stem (that this thread started with) seems to work ok. Came loose once and had to redo the operation with a bit more force. Crossing my fingers it will stay put...
M/s turned out to be broken but found a close enough one in my small stash that gives an amplitude up around 300 degrees, fully wound.
Picture attached. Nothing fancy and a bit rough around the edges but quite ok as a start and I will definitely keep my eyes open for the next one.
    • I understand the demand bit, the generation below me 30ish are too technology engrossed to own a mechanical watch and they just dont like old stuff. I also consider myself at the getting on age of 57 to be a rare find of someone that likes old stuff, i did buy an almost 100 year old book yesterday titled " The New Modern Home " printed 1929.  Cost me a quid. What i was trying to work out is if we have reached a volume peak of watches being discovered hidden in the back of drawers.  Those watches that were hung onto until they entered the hands of the non sentimental generation.
    • Even for myself who only started getting into watch repair/servicing during COVID I have seen a huge jump in watch prices - we have a 404 channel on this forum. When I started you could relatively easily find a watch on eBay to restore and put onto the channel, however this is now almost impossible and the only feasible solution is to buy a job lot with an average price <4.04. Even watches sold for parts/spares are 3 or four times the price of only a few years ago. Why - Either Demand must have increased in order to push up the price, or supply is reduced. I think it is a little of both, I think that most watches in the UK/US may have been picked over, which agrees with most of what @Neverenoughwatches says so supply of all kinds of vintage watches, including tat is dwindling. As a double whammy I think that more people are wanting watches, either to work on, or as a way to differentiate themselves from the Apple Watch and FitBit crowd. The upshot is that half decent watches that require restoration are now $500 instead of $100 and cheaper watches (Seiko 5 etc) are now $50 instead of $10, and even Mumbai Specials and garbage are now pushing $50 each. When - how long will this last, I think that most of the people who are returning to mechanical watches are those that have previously experienced life without them and want to return to something with a bit of personality that doesn't buzz every 10 seconds on your wrist and tell you how many steps you have done today. i.e. the 30-40+ generation. My son who is 17 has several mechanical watches but only wears one on a special occasion and is obviously only aware of them at all in part due to my hobby. I asked him the other day how many of his friends wear a watch and he told me that some use a smart watch but most just use their phones. So as I see it, demand will start to fall once the sub-thirty crowd start becoming the majority and/or the older amongst us stop buying watches and switch our attention to mobility scooters and trying to remember our bank password. Price - I think this is here to stay, even if demand does start to drop as the older generation becomes to decrepit and stops buying and the younger generation isn't interested in buying, supply will become progressively less as time goes on as more vintage watches become lost or broken beyond repair. I think the prices will plateau at some point as an equilibrium is reached as reduced demand is balanced with reduced supply, i.e. less and less people buying less and less watches. Sorry for the long ramble!
    • Hi. Use a PVA based glue, gorilla glue it dries transparent then do as advised by Old Hippy, smoothe down using very fine  0000 wire wool and either French polish or beeswax for a finish.
    • Hello and welcome to the forum.    Enjoy
    • The problem with oil in particular 9010 is it likes to spread. This is why you're supposed to use epilam anywhere it's used to keep the oil in place. Then you want to splurge on money you could buy 941 it's actually an oil that existed before 9415. Then the problem with the grease yes it stays in place but if you have too much you lose amplitude. Then if you get really obsessed with this he would follow Omega's recommendation for escapement lubrication. One of the problems with internal documents of the watch companies is typically are never going to see Them.But a few of them out in the wild for instance at this link Below I searched for the keyword of working. In particular working instructions of the Omega watch company for which there is way more than This but this is all they have. So you want to download number 40 as were going to talk about that and also download Number 81. Plus anything else that looks interesting https://www.cousinsuk.com/document/search?SearchString=Working Then number 40 covers lubrication of the watch. Most interesting is lubrication of the lever escapement under three different conditions with Lubrifar Which you probably no longer have has been washed off without which is what you have and then a course with epilam. Notice how they go supers super minimalistic with the 9415 because if it's too heavy you lose amplitude. Then if you lose amplitude the group will be disappointed with you and the end of the world will come.
