Shaping a ruby pallet stone
Buffo
I suspect that you're going to need some kind of a diamond lap to do that.
It's not something I've ever tried to do but I would imagine your going to need a jig of some kind to hold everything true, and then successive finer laps to first remove material and then polish the surface.
I'm not sure how the OP thinks he can do this, but if with the stone in the fork, assuming it would be even possible, then the stone will become too short and not have the right lock and draw.
Faulty stones should be replaced.
Thanks for the responses.
I realize that diamond is probably the best option, but I have managed to shape and polish corundum in the past without resorting to diamond polishing compounds.
I would not attempt to do any shaping with the stone mounted in the fork. I was thinking more of dopping a stone (I've got a small selection to choose from) on to a stick (tooth pick) and gently working it to the proper length and angle.
The movement I'm having a go at is a 1923 Elgin 16s, 7 jewel 292 cal. The escape wheel is in good condition, but one of the pallet stones on the fork is "cactus." As a last resort I can splurge on a new complete pallet with stones from Cas-KerCoy, but $50 USD is a bit much for this Aussie. Besides I kind of like the idea of seeing if I can get this thing ticking again with what I have at hand.
In theory you can work ruby with anything harder or as hard (diamond is worked with diamond), but it's so easy and cheap to get diamond lapping compounds and powders that it's really the way to go. I'd suggest a copper lap rotated in the lathe, but almost any material is ok- acrylic, iron, etc. For pallet faces I would use 1micron diamond, it will cut slowly but surely and leave an entirely satisfactory finish.
jdm and nickelsilver, thanks for the URL and the excellent suggestions on laps and lapping compounds.
I have ordered a selection of stones that is suppose to contain pocket watch size specimens from another supplier. As it might be possible to find a suitable pallet stone in a random selection, I do believe that shaping and adjustment will still be necessary, hence  my question about lapping compounds.
I value the responses of all who replied and thank you for your excellent suggestions. I'll try to let you know if I have any success at this endeavour.
Buffo
Buffo
Generally speaking you can replace a pallet stone with another of the same width, and that has been shaped for the appropriate side of the fork (entry or exit). Let's say for your average vintage watch, a replacement stone from Seitz or other assortment will probably be just fine. You do run into issues with certain escapements for higher end watches from back in the day or modern watches with higher beats and more teeth in the escape wheel; often older high end escapements might have significantly different face angles from "common", and modern escapements have very different angles for sure. Usually it's possible and normal to replace an entire fork for a modern watch. With vintage/antique it can be very advantageous to fine tune the angle on the impulse face.
One issue with replacement stones is that they are sometimes just too long overall, and need to be shortened. This is usually done on the end that fits in the fork as it just needs to be approximately squared off; I do it with a fine diamond grinding wheel (7 micron) holding the stone in a tiny vice. I suppose it could be done with a fine diamond file, but these will tend to chip the stone and while not affecting the function it is unsightly.
  • 1 year later...
I’m reading the chapter “Replacing a Pallet Jewel” in Henry B. Fried’s book “The Watch Repairer’s Manual, Second Edition”. On page 204, he suggests how to shorten a pallet jewel and I quote:
“Should a jewel be chosen with all dimensions correct except that it’s too long, it may be shortened to an acceptable length. This is done by drilling a fine hole into the end of a piece of pegwood and placing the jewel, lift surface (impulse face) inside, so that the excess length is the only part protruding from the pegwood. The jewel is shellacked into place, and the protruding end is held against a diamond-charged lap or wheel…”, etc.
So, this seems like a nifty but somewhat cumbersome method, especially when compared to your suggestion of using a "tiny vice". Furthermore, I can’t figure out is how to shellack the jewel into place in the piece of pegwood, and the chapter doesn’t explain or suggest how it can be done.
So, I'd rather use a tiny vice like the one you mention if one can be had. Can you perhaps tell me a bit more about the tiny vice you use (the shape/material of the jaws gripping the jewel), and perhaps suggest where one can be obtained?
I don't have a diamond grinding wheel or the machinery for such a wheel, but was hoping perhaps I could use my 3M lapping film. However, as you mention: "In theory you can work ruby with anything harder or as hard (diamond is worked with diamond)" so maybe it isn't such a great idea? Any alternative suggestion for the budget of an amateur repairer? I do have a 1200 grit diamond stone which I use to dress my screwdriver blades, but I'm thinking it's likely too coarse and would make the jewel look, as you put it, "unsightly", or what do you think?
Edited by VWatchie
The little vice I use is made by Horia. It's not cheap but very excellent. Mine is 21 years old and gets used several times a day, every day. I have seen similar/copies in catalogs since I bought mine for about half the price, but can't remember where now. It's a typical tool young watchmakers might make in school (if they have free time) as it's a good exercise and very worth the effort- but you would need a milling machine to make one.
https://www.horia.ch/en/Products/Tools/Tools/Vice.html
For diamond abrasives on a budget Eternal Tools is hard to beat. I can't remember if you have a lathe or not, if so you can buy cheap diamond paste from numerous suppliers and use it on a lap as I wrote above. You will want a separate lap for each grit, the whole idea is it embeds into the lap- there's no cleaning it off. Eternal has diamond wheels and round laps down to D9 or 2000 grit, which would be fine for shortening a stone. You need finer, at least 3 micron to work the functional surfaces.
https://www.eternaltools.com/
Edited by nickelsilver
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
