Chinese clone horia tool
55 minutes ago, JohnR725 said:
Thinking about other tools here's an example Of another Chinese tool. In Seattle we have a school sponsored by Rolex teaching professional watchmaking and one of the students who had met had one of these before and one of the current ones I know it purchased one and as we're talking about Chinese tools this is a perfect example. Not something I would ever use but apparently the students like it and this is what was done to it notice it has a familiar sound doesn't it?
All things considered, it worked very very well outside of the box but I did service the entire thing. Disassembled it, cleaned off all the manufacturing oil, polished the pivoting points and then lubricated everything. It now works phenomenally.
https://www.aliexpress.us/item/2255800157901825.html?spm=a2g0n.order_detail.order_detail_item.3.2e12f19cloFdqx&gatewayAdapt=Msite2Pc
I do curiosity to see what it cost from the Swiss here's what cousins is selling it for. Yes it does appear to be quite a difference in price.
https://www.cousinsuk.com/product/hand-fitting-multi-press-watch-bergeon-swiss?code=H40483
I also have one of these, its a little off target and on my to-do list to disassemble and tweak.
Me too. The pushers are a good fit in the spindle, the anvils are a little slack in the base. Both seem to line up ok but occasionally need to adjust the anvil's position within the slack on a small jewel. The mating surfaces on both the pushers and anvils are a bit rough as is the base seatings on the anvils. This does need addressing, when practicing i have noticed the jewel doesn't always enter the hole perfectly square on.
I'm about to order one of the horia clones from ali, this will my first jewelling tool, the ali ads are confusing me, when i read the different sellers ads some listing say 4mm&4mm, and then it also says spindle hole 3mm, table hole 4mm, in the same description.
Are the pushers and anvils both 4mm or are the pushers 3mm and the anivils 4mm.
What size did you get when you received your horia clone.
Edited by valleyguy
The one i have is pushers 3mm and anvils 4mm.
To add to the topic of Seitz (lever) vs Horia (screw).
Some Seitz presses were shipped with "thickness micrometer" attachment. I was lucky enough to score one of those before knowing what exactly it's used for.
If the zeroing screw is taken out, it effectively performs as Horia tool (pushing down the spindle by screwing in the micrometer screw).
I've documented different variations of Seitz (lever vs lever + thickness measurement) here: https://imgur.com/a/hJALq7f
Edited by everyonesdesign
Used more proper word for an example (jewel -> spindle)
Thanks for this I will personally investigate.
  • 2 months later...
On 6/1/2023 at 5:02 PM, Knebo said:
putting a mainspring into the barrel
Quick note on my earlier post (see above): DON'T DO IT like that. It worked fine once because the anvil happened to fit extremely well. The following 2-3 times it always failed and I had a messed up mainspring.
This approach is actually quite fail safe:
I use Rodico to stabilise the brass tweezers and to ensure that they push down on the barrel evenly. I push down the tweezers with one hand - important is to have a fair amount of pressure so that the barrel can't slip away. With the other hand I pry in the mainspring with a screwdriver (flat side). It hasn't failed me yet.
I realise that this is off-topic, but wanted to make sure nobody follows my bad example above with the Seitz press.
Edited by Knebo
    • Post some pictures , some good close ones of the parts you've described.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
