MAIN SPRING BOUND :
21 hours ago, rogart63 said:
Not sure i am with you there? Is the ratchet wheel hidden so you can't unwind it? Like a citizen or Baumgartner 866. Pictures could help? Or movement?
  the click (paul) is a rachet for the rachet wheel,  part of the mainsping barrel.  correct?  the watch will not run if the main spring is (up tight).    if you want to take the balance out. "let down the main spring".    this watch has the winding stem "locked up",    can not let the spring down. i want to avoid a total tear down of this valuable watch.  SO,   if i can find the click and release it,   a total tear down MAY be avoided.  are you with me now?    cheers,   vin
On ‎12‎/‎9‎/‎2019 at 10:58 AM, nickelsilver said:
The click on a 72 is next to the column wheel, there's a pin sticking up through the bridge that you can hold to let down the power.
     the  click moves and is not under pressure.  so the bind is in the area of the spring barrel or the winding gears. needs tear down.  thanks for the help, ill put it away for a while.   vin
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
    • There are some parts on Ebay for the seiko 6020A, it may just be a waiting game for someone to strip one down, NOS will be more scarce . K would strip your movement down to the module then start looking at other seiko movement to see if that coil is used, then seek out a seiko part dealer. Also Retrowatches youtube owner Mike may give you some advice try him on his site . He also hangs around amateur watchmaking groups.
    • I would agree, in order to work harden something you need to exceed it's yield strength when it moves from the elastic zone to the plastic zone and you get permanent deformation and work hardening which is fairly close to its failure point, relatively speaking and dependent on the material/alloy of course. In theory you can load something constantly within its elastic range and not suffer work hardening issues.
    • Probably easier to get a complete new movement - but CousinsUK list it as discontinued. Maybe someone on here knows a substitute movement ?
    • Any other thoughts on how I can get a replacement coil? Any “hidden” or unknown physical shops (in Australia or elsewhere) that might have them in stock (but not always online)?
