HI All
I'm a beginner and I appreciate all the coaching I've got from members here.  Very helpful indeed.
I just completed a service for an AS 1950/51 which I picked up as a non-runner (I gave up on it's date jumper spring from my other thread) .  Looks great on the TG.  The movement spacer is missing.  My US supplier list these replacements https://www.jewelerssupplies.com/shop-bin/sc/productsearch.cgi?search_field=movement spacer
Ranff gives us a diameter of 26MM (11.5 ligne) http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&AS_1951.  The case is a large diver style.
Would the 11.5 ligne assortment be the best bet?
Thank you
Charlie
Edited by Lc130
Put the movement in the case and measure the distance between movement and case and the height. That will give you the size you need.
