This might sound like an odd question, but would it be possible to remove the date function from an eta movement? I am working on a project watch I am designing and building and I can’t source myself a movement with the desired specs that doesn’t have a date function.
Short answer is yes. You can remove the components that make up the date complication, however, you can't remove the stem position. In other words, there will still be a second position when you pull the crown out where you would normally adjust the date, it just won't turn anything.
Edited by mousekar
I presume ETA self winders, you can eliminate the date complication, since date train is independent on em, that however dose not reduce the height. Base calibers have no date.
Dr ranfft  lists variants of all calibers.
Absolutely yes, as above though there'll still be the intermediate position but as you won't gain any extra space you could simply leave the calendar works in place and put the dial over the top of it.
Edited by m1ks
Thanks for the answer, however Sellita has responded to me and they sell the movement without the date function! So it shouldn’t be a problem!
LiamB,
Not sure what project you're doing but sometimes watches without day/dates have different dimensions.
So if you are trying to fit a no-date movement in a watch case which previously held one with day/date you may find the stem hole in the case and movement do not line up.
If you are in contact with Sellita they should be able to provide you with the dimensions and you can compare that with the movement you're replacing.
Good luck!
Anilv
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
