Hi everyone,
Sorry, I know this is a question that's asked alot, but would value your opinion of the state of this mainspring.
It's an old blue mainspring, unsure if there's still life in it, what do you guys think?
Is it tired or still acceptable to use again?
Thanks.
If you can,t get a new replacement ( best option),  I guess the movement itself is a tool to measure the strength in.
I instal and measure the running time.
Just curious, what movement is this? Reason I ask is that a lot of Russian movements have hairsprings which look like this, even when new.
Anilv
Anilv
Most steel springs look like this, even new. If they open up bigger when band new then they look like this after one or two full windings.
Anilv
12.68n longines
18 hours ago, BeyondWorld said:
12.68n longines
I just got hold of a Longines with the cal.12!
Anilv
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
