Quartz submariner not working
markr
I got this little beauty  at a swap meet on Sunday.  I changed the battery and still nothing.  I know nothing about quartz. Is there a trick I kneed to know?  Is it worth taking down to be repaired?  Should I look for an ETA movement to put inside?  It does have the gold matching band in good condition.
If you can't easily find a replacement movement, then you might risk stripping off the dial and hands (assuming this is possible), and cleaning the mechanism in lighter fluid.
This *might* get it going, however if the coil or the circuit is damaged, then your luck is out, and you will need to keep searching for a replacement.
Edited by AndyHull
1 minute ago, watchweasol said:
Hi   might be worth a fiddle,  Swill out with Naptha and a spin on the line release. No dismantling that one.
I have fixed a couple this way... well slunged in lighter fluid and dried in front of an electric fan heater, but basically the same method.
Bear in mind that naptha/lighter fluid is obviously flamable, so take care not to set things ablaze when evaporating off the excess. :blink:
