WWW Eterna sucked me in.
luiazazrambo
The next one is a set of opening tools for burnished in jewels. I was very happy about this as I have an unfinished business with my wife's watch where the jewel seat was too small for all the opening tools I own. Unfortunately the smallest is broken the next might do the job though. Of course one could make his own tool if there is time and will.
9 hours ago, AndyHull said:
You could maybe replicate the stamping with a drill press and suitable tool holders as the pressure wont be very high when dealing with softened relatively thin, pre-heated acrylic sheet.
Don't be tempted to simply roughly line them up and whack them with a hammer however as if they are hardened steel they may not survive the process.
Once I wanted to pick up a fly press from FB marketplace, but I was too slow and somebody else got it. It was really cheap and also good at the same time. I wanted to see if I could mint some coins with it. Just before last Christmas we went to Jorvik and in the Viking museum they made a coin (aluminium) for us with a hammer.
The Jorvik Viking museum is always worth a visit. You can easily spend a couple of days in there.
Fly presses turn up on ebay quite a lot, and they are pretty useful, but heavy and often pricey.
You can also use a car jack and some steel or wooden framing if you want to crush or press stuff. Crude but effective. More controllable than a 4lb sledge hammer or a mashie nibblick. 😋
I'm not sure if HM Customs and Revenue would really appreciate me minting my own coins, although maybe I could whack out a few new Scottish 2022 bawbees without ending up in the tower of London. Nemo me impune lacessit and all that.
Edited by AndyHull
Hi  No they are holeclosing punches, the center point is sprung and placed into the worn hole then the punch is tapped with the hammer. The outer rim of the punch spreads the plate closing it. an easy way of repairing worn plates onle problem is it marks the plates and is used from inside the plate. Once closed up a bit it is then broached to fit the pivot assuming the pivot is ok or having been replaced.
That was my second thought. It is described in one of my book as how to "fix" worn pivot holes. One of the center section of a punch from the French set stayed inside of the punch because somebody used it to make a hole in some textile, i know this because the textile stayed in the hole not letting the center section out. It stayed there even after I removed that material. Tried to put some light oil in it and agitate it and I can move it a bit downwards so it is moving, but would not fully come out as it is supposed to.
Ok I scanned the pages I talked about, then it went through a pdf to text engine, google translate and correction by myself, then back to pdf because text files are not allowed here. I had difficulties with English, almost gave up. Please check it out I left a surprise in the English translation.
pivot_holes.pdf repairing_pivot_holes_eng.pdf repairing_pivot_holes_hun.pdf
I got no watchmaker's lathe and now I got three of them. They might need some attention though. Unfortunately I have no motor to drive them yet and know knowledge to restore them if needed or generally speaking no turning experience. Both knowledge and motor issue can be sorted only time is limited.
These came in today. The one with the blue handle is on sale for £1.9+VAT on Cousins website. I am planning to modify it a bit to be able to remove hairspring pins. I am having difficulties with them and I tend loosing them. Not sure if it will work, once I read that someone made a small tool for it but never seen it.
10 hours ago, Plato said:
@luiazazrambo are you buying tools in bulk for yourself or are you trading? I love watchmaking tools but it takes a bit of time to understand each one, you might end up overwhelmed if you buy so many at once!
I do a little bit of both but I tend to keep every tool I can put my hands on. I must find the funds for this hobby somehow so I came up with different ideas especially now when I own the family budget with a considerable amount. One life is barely enough to master this even if you spend 10-16 hours a day in your workshop like George Daniels. Watch "The Watchmaker's Apprentice" on Amazon if you can. I only got the odd hours when family is already in bed and a couple of hours daylight fun at the weekends.
Edited by luiazazrambo
Nice, is this Lorch lathe 6mm or 8mm? I have a 6mm one, good little lathes are  Lorches, love mine,,
The one on its own is a Lorch 8mm, the other two are Wolf Jahn 6 and 6,5 mm. The 6 mm has actually a Lorch bed. I am very happy to have them, but dont know if they are any good yet. They might have issues, time will tell.
Good source of information: Watchmakers Lathes
A little bit of a restoration. Not perfect. I probably should have done the whole outside, but I am not sure that the glue I have or the paper I have are ideal for the job, well the glue certainly not and the project also would greatly benefit a little bit of more experience doing this job.
And the mysterious tool is actually not a watchmakers tool. Its a  mechanical dotting pen for drawing, from E.O. Richter, Chemnitz.
Dotting pen.
I tried to insert a graphite lead into it and it worked well, but only for a short period of time before the lead twisted out from its place. I don't know what was there originally and how was it secured properly.
    • Once you have the collet closer bits off, and the pulley off, there are two nuts on the spindle. These must be removed. There is a large nut in the back of the headstock with two holes, remove this with an appropriate wrench. The front large nut comes off too. The spindle now comes out- but wait- there's more! There is a spacer between the outer races of the bearings; the spindle will almost certainly come out "assembled" with both bearings and this spacer (it can actually come out front or back-ways with the large nuts off the headstock). You have to manage to press out the spindle from the rear bearing, get the spacer off, then remove the front bearing, now you can get to the key.   Imagining you get it all apart without causing any damage to the bearings, now the fun part starts. You must apply preload to the bearings, and this is a very tricky endeavor. Basically once you have the bearings back on, and are in the casting, you snug up the rear nut (one of the two) on the spindle, checking the play of the spindle with at least a 0.002mm reading indicator, until there is zero axial play, then just a little more, then snug up the second nut to lock things in place. Of course snugging up the second nut influences the preload, so you can go back and forth a few times to get it right. Too much preload and bearing life diminishes, too little, and you get poor performance, poor surface finishes, ball skidding, etc.   When I replaced the bearings in one of mine many years ago, I was surprised to find that the bearings were regular deep-groove bearings, but of a higher precision class than normal. I replaced with dimensionally identical angular contact bearings, class P4. In trying to set the preload, I just about lost my mind, so called Barden (the high precision arm of FAG bearing makers, and who made my new ones) and a nice engineer told me that the folks at Leinen were either crazy, or really good- he also said it's 100% A-OK to set up deep groove bearings with preload like this, but best is angular contact. In this bearing setup, the standard way to do it is to have a spacer between the outer races, and another between the inner races. Leinen has the former but not the latter, haha. His advice was to make an inner spacer. The trick is it has to be the exact same length as the outer spacer, within like a micron.  Then you just tighten everything up and the preload is set, because the bearings (the new ones) are ground in a way that they have proper preload in that situation. Easy. Sort of- if you have the means to make the other spacer!   Just to note- Schaublin does the preloading as Leinen did on these on their lathes using angular contact bearings. There is a procedure in the manual, where you tighten the nut until axial play is zero, then a certain number of degrees more. This works on their setup as the nut itself locks without a second nut, and they spent the time to figure it all out in a repeatable way.   I say all this not to scare you off from dismantling your headstock, just to give a heads-up what you're up against to get it back to where it was before.
    • Do, write a nice letter to Santa. I do all disassembly and assembly under the microscope. I consider it a necessity.
    • Yes Breguet overcoil, and A is OK, the damage is from B to the end. It should look lile this. The studd is fixed by the screw head into  the cut.
    • I opened up a 17 jeweled Swiss made movement only to find it has a pin pallet escapement. Not sure where the 17 jewels are but they ain’t on the pallet fork! Tips for lubrication?
    • Hi, This headstock is a little bit too modern for me to know my way round it. The pin that stops the collet spinning is sheared and needs replacing. Does anyone have advice on how to remove the spindle? I’m assuming that you remove the quick change assembly from shaft. Remove pulley. Unscrew front and back bearing plates on the headstock. Then press the spindle out applying pressure to the front (collet end). Has anyone done one of these? Any pictures or links to articles/literature gratefully appreciated. Thanks in advance. Warm Regards   Andy
