Remove movement Citizen 5204
One needs to post pictures back and front to help others help. Likely however it's a front loader, search this forum for the many threads about that.
Edited by jdm
Hi, Jdm is very right. Picture helps a lot, Advice will be pouring in.
   Dr ranfft website show most any mass produced movement.  To make inquiry search like this,
Citizen5204 ranfft.
You can get the movements image off of the site and post on this here thread, showing what are talking about.
Best wishes
Hi researching a little deeper it looks as though the bezel ring comes off and the cryatal  is removed allowing the movement to pop out (see attached)  as long as the movement retainer lugs and screws are removed.  Information gleaned from the  Seiko/Citizen   SCWF.
The bezel is under the glass. It is dirty but it seems that the ring around the glass is part of the case.
Does anybody know what kind of glass this is? It is clearly very scratched but not sure it doesn't look acrylic although I can't honestly say
What you call bezel is the chapter ring. The bezel may seem one part with the case but isn't. If you look around the seam with a loupe it may have a small reces to start prying. Otherwise work around it with a blade like an ☓acto knife. Once you have some light continue with a case back knife.
Edited by jdm
Hey ... I just serviced a similar one with a 5470 inside. And it had a retainer ring.... That was a big tricky to take out but that came out at the end. The retainer ring is actually where the screws sit to hold the movement in place.
Thanks jmd, it was actually easier that I thought. I came out nicely on my first try.
I can finish now the disassembling.
    • Right now I'm making do with a similar micrometer (the one below is $45 shipped but you can find better deals) and a $20 stand. You do have to be excruciatingly careful measuring jewels, since there's no table, but if you don't have the $500 to throw around, it's a nice option.
    • As  I kid, I'd watch Godzilla stomping over buildings and cars and I'd think to myself: Tokyo is a really dangerous place to live... . Cool watch!!
    • Next one up an AS 554, looks like a bit more to this one. First job is to check thickness, most springs are somewhere between .3 and .4, this one measures .35, that matches in with the .4 spring steel i ordered. So for marking up a permanent marker comes in handy to colour up the steel to be marked later with a scriber once its dry. Bestfit provide the extra bit of info for the jumper spring that is missing.
    • Thanks again, Marc.  Super helpful. I was wondering what the hole was for, and now it makes perfect sense. With your help and the other members here, it looks like I'm good to go with my Seitz tool set. I had to order some replacement pushers, but with those, the set is complete and in good condition. Now, I need to figure out what tool to buy to measure jewels (amongst other watch-related parts). I had my eye on the JKA Feintaster micrometers, but people get crazy bidding on them for $400-600 USD. I was thinking of just a regular digital micrometer (Mitutoyo). Thoughts?  Mahalo. Frank
    • Yep, that's exactly how it should fit. The reamer shank is tapered and the socket in the spindle is also tapered so that the one centers in the other and is gripped tightly. If there is any wobble when the reamer is seated as far it will go then there is a problem. The cross hole in the spindle is to allow you the push the reamer back out again. If the reamer seated much deeper then it would limit the access for pushing it back out again. Here is one of mine for comparison.
