Repair Rub In Jewel Setting
So, I was somewhat cavalier trying to replace a rub in jewel. I don’t have the correct tools but thought I could expand and close the hole with nothing but my jeweling tool, some peg wood and my wits. It didn’t go well. I’ve taken a big. chunk out of the thin metal that wraps around the jewel. To be fair, the jewel still sits in the hole and feels relatively secure with only 200 degrees of metal holding it in place. But I just can’t close the watch knowing it’s been bodged. So is there a technique for replacing a rub in jewel setting if it’s damaged? I’m guessing it needs drilling out and soldering in a new setting. Which would be beyond me for now. Is there another way?
Thanks both. Could this help me create a new larger hole? And I'll just find a suitable jewel to fit? I've never seen one of these before and I have no idea how they work.
https://www.ebay.co.uk/itm/Vintage-Watchmakers-Jewellers-Brass-Jewel-Hole-Cutting-Tool-Set-Boxed/383062301696?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
That's for making a new setting. I haven't used one either but it's a neat looking tool.
A big problem when replacing bezel set (rubbed in) jewels is that the brass or german silver is often quite brittle. If it's a regular commercial grade watch and you don't mind altering it, the easy route is to ream the setting to the closest friction fit jewel that will go. In some cases you can use the "walls"of the old bezel set jewel. If it's a nice piece, like an old LeCoultre or something, I will open up the bridge or plate in a faceplate. There is almost always a polished sink around the setting; I'll open up till that is gone. Then make a new setting that frictions in, which gets the polished sink on the visible side, and the repair is effectively invisible.
Well I purchased that tool. Just because it looks really interesting. I'm not sure how it works but I have plenty of scrap movements to practice with.
I might see if it helps me make a new setting. But more likely I'm going to ream out a friction fit hole as suggested by Nickelsilver above.
The question is, what stone should I buy?
The jewel is for a pallet fork (lower). The fork pivot is 0.141 according to my super accurate micrometer. If it's anything to go by the upper jewel hole looks to be around 0.2mm. But it's tricky to measure. Would a 0.2mm hole be correct for a pivot of this size? I'm not sure what the ratio of pivot diameter to hole diameter should be for a pallet fork.
I measure the jewel setting diameter 1.51mm. But it's also difficult to measure.
I was thinking of going for a Seitz flat jewel 1.6mm with a 0.2mm hole. (Seitz don't make an olive jewel in this size.) Does this sound sensible?
So, here is the interesting jewel cutting tool from eBay. Just arrived today. It's really nifty. I can't find anything about how to use it so I'm making this up as I go along.
Let's define some technical terms.
1) Turny bit
2) Spiky thing
3) Edge gougers
4) Locking screw
5) Size guide
6) Maybe thing for a bow
It appears that you place the spiky thing into your desired jewel hole on the size guide. You turn the turny thing until the edge gougers fit into the guide edge of the hole. Then you lock the spike with the locking screw.
The edge gougers are clever. Each one is split. So I think the inner gouger carves out the floor of the setting for the jewel to sit on. And the outer one creates a wall that you can later use to bend over the jewel and secure it. Because am I right in thinking this is producing a rub in setting?
I had a couple of gentle attempts on a thin scrap piece. I used it to ream an existing hole. I would presume you need a pilot hole to start with close to the correct size. I wouldn't like to use this to make a hole from scratch.
I am using this freehand. But would you agree that 6 could be a thing to use a bow? Like you would with a jacot tool? But then the tool needs to be held on some kind of stand or device to keep it vertical and steady. So I'm not sure. It certainly doesn't feel very ergonomic using it freehand.
And why are both ends spiked?
The rear point would have fit in a divot in a vice to support it while it was worked with a bow. The plate would be handheld. Yes you need a premade hole to begin with.
Watchmaker's vices used to come with the little divots in the jaws for the many bow powered special tools.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
