Vintage watch help
The five star admiral Longines, looks genuine, original hands, dial. Good brand.
Evidence of moisture inside the case therefore the movement. I would remove the back, peak inside, send picture and test the set mech, winder.
Moisture damage to the dial, greately reduces the value. Aprox $350
The vulcain, dial is looks suspecious, examine close see if painted, see if the word swiss appear at six oclock. $30
Tissot, check the extend of water and other damges inside, $25
Seiko chrono aprox $150
Between the two of us, take ths GUB home, very liitle work. Best of the herd. Don,t know a price.
The Russian one, just that its chrono. Values not much.
My appraisal is usually ignored.
All of these watches are mine. I'm just waiting on them to be shipped. Plus alot of seikos as well.
Sent from my SM-G965U using Tapatalk
Enjoy em in good health, I would post a query for advice on how to the longine dial, or have it cleaned.Unless experienced you shouldn,t attack the dial.
Best wishes.
the reliance will likely have a seiko movement akin to the 66..The ones I have seen were sold by croton as their budget line, something like a caravelle by bulova.
Edited by yankeedog
content
Do you know what movement the admiral 5 star is expected to have?
I thought NuceJoe would say the caseing on this one is unique he usually has a sharp eye, I haven't seen it before since the most of these came with an 18k gold case.
Depending on what year the watch was produced it came with a range of different movements, here is a selection..
calibre 340
calibre 501
calibre 506
calibre 507
calibre 508
calibre L 636.5
calibre 1753
calibre 6651
Since your watch looks like a 70's piece I would guess it should have a calibre 50X inside, but this is a tricky one..
calibre 340
calibre 501
calibre 506
calibre 507
calibre 508
calibre L 636.5
calibre 1753
calibre 6651
Ranfft says its a record which longine acquisitioned, yours should be  recod  or longine 508 .mine is to change date by repeated pushing it dosn,t , you guys have a pic of the date jumper?
When I get the 5 star I'll open her up and we can look at it
2 hours ago, manodeoro said:
May I guess the Reliance could have Lorsa ?
Possibly a P72 or P72A ?
Envoyé de mon Moto G (5) Plus en utilisant Tapatalk
Lorsa is of course a possibility..but since I didn't see the word FRANCE at the bottom of the dial.I thought JAPAN.
Edited by yankeedog
Spelling
That Reliance really looks like my Leon Piraguet 17 jewels ... case/bezel/crown/hands/etc ... even the design of the dial is similar except mine has a Lorsa P75 inside.
That's why I thought about a Lorsa P72
Entirely possible! I have a Leon piradet with a slava movement..so who knows!
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
