Automatic mainspring barrel 'Brake Spring' for AS 1902
Sorry, editted parts of different paragraph.🙃 Treat Foxodrop & carrier alchohal .
Nothing would be easy for a newbie, including getting several different size mainspring winders. Therefore, a newbie should learn how to use hands, tweezers, 1.4-1.6mm flat screwdriver, a flat punch to manually install T-end mainspring into a barrel. And Yes - Safety First (safety for mainsprings) - use finger cots to keep the spring clean during installation. This subject was discussed in the past more than once:
For third and escape wheel upper cap jewels i use seagull 1.00 x 0.14mm (J66703 from cousinsuk) in 7s26 and nh3x movements. Shock spring is 015.703.
So you apply the Fixodrop after oiling? How do you apply it? Thanks.
