No, I don't collect the vintage character watch series made by US Time and Timex.  But I have restored a number of them and typically the strap is missing or well worn.  Some had very distinct straps and trying to find a suitable replacement is not easy.  Ah but, what if you could find a NOS?  Not so easy to do and I thought I never come across one for the Hopalong Cassidy.
You know the one with the big buckle and metal tip.  Than I get in a huge NOS lot from a retired salesman and found this >>>>
Edited by JerseyMo
typo
  • 4 weeks later...
Some things are just meant to be and that strap had your name on it. Well done!
Is it just me but, somehow I feel a little sad when I have to separate the strap from an old watch that have been together for goodness knows how many years. I have just stood in front of the waste bin with the strap from a watch that has been worn to the point it had assumed the shape of the owners wrist. The fastening hole was elongated by many years of use. I felt genuinely guilty about letting it finally drop into the bin. I can’t help but think about the person who might have owned it, the places it has been and the stories it could tell. I think I must be getting more sentimental with age.
You could, of course, attempt to restore the strap. Some of the leather ones I've encountered did actually restore quite nicely.
I even re-stitched a couple of them. Others however are so badly worn that they are beyond hope.
1 hour ago, Davey57 said:
Yes I have rescued one or two, but some are so disgustingly ingrained with “stuff” I could not bring myself to use them.
yep, as with all straps and bands there can be some seriously funky stuff growing in there!
  • 2 years later...
I have recently restored a few of these Hopalong Cassidy watches. This one came from someone who bought it as a boy at the end of the 50s for Christmas. I am jealous! 🙂
Edited by luiazazrambo
I cant say I had no difficulties. I was ready with the one you can see on the pics once then i was checking its performance on the timing machine it looked brilliant so i tried to regulate it while i was working from home. Just a light touch with my tweezers reaching it over my computer.... my tweezers slipped and i literally destroyed the HS. I was so sick I could not revisit it for about two days. I sourced another HS and as far as I remember I also ruined the pin pallet while I tried to clean it so I had to source that too. (the pins were stuck in rodico and the rodico pulled one of them out when I tried to lift the fork up, i put the pin back but it was not tight enough anymore) You can buy ladies watches with M21 on eBay for about £2-£4 as a donor movement. I have serviced another M21 since this one and another two M22s are on my desk. Just like with anything else everything gets easier/quicker to handle if you practice it. Originally I could not even imagine how to put the main plate back and now I don't even consider it as a difficult task, it usually goes back all right for the first try.
11 hours ago, magic2020 said:
Got one just like that as a present in 1956  (I'm 75), but hesitant to do anything with it in case I fail miserably!
Maybe one day?
If you need advice or parts let me know I am going to try to help you the best I can. Take care.
    • Thanks for shedding light on the exact problem — you're right, it's the centre tube, not the cannon pinion. That was the issue, and after tightening the centre tube, everything now sits correctly. The train bridge can be fully tightened and all the wheels run freely. I haven’t tested the pallet fork yet as I haven’t refitted it, but I’ll be doing that shortly to confirm if the issue is entirely resolved. @Neverenoughwatches Sorry for misusing the term earlier.
    • If the existing spring is 0.06 then it's been replaced at some time in the past and would potentially be too weak for this movement.
    • A quick addition: Given when I measured the springs I got 1.5 x 0.06 I thought I'd figure out how long they are. I was able to do this from a photograph taken immediately above. The program Inkscape has a nice extension that allows measuring the length of a beizer curve, so I drew one along the length of the spring. It's 220mm. And 1.5 x 0.06x 220 x 7.0 does appear in the catalogue. It would also explain the lower amplitude I'm seeing.  Doesn't immediately solve anything, but the information is nice.
    • That's because it's not a cannon pinion and just a centre tube. If this was the fault I still wouldn't have expected it to run without the balance. Edit @TimepieceTinkerer To clarify. Did you test the train ran smoothly with everything tightened down before fitted the fork and balance?
    • You're absolutely right — normally, a missing or even removed cannon pinion wouldn't stop the train from running or the movement from ticking. Just to clarify: the part I’m referring to isn’t the removable cannon pinion on the center wheel — it’s the fixed pinion that’s pressed into the mainplate underneath, which drives the motion works. I may have misused the term earlier. That pinion was loose in my case, and it caused the fourth wheel to sit out of alignment, which jammed the train when the bridge was fully tightened. Once I tightened that fixed pinion with the staking set, everything seated correctly and the issue was resolved. Appreciate your input — and thanks for helping me describe it more accurately.
