New Member
Good morning and thank you for the welcome. The clock in question is a Gustav Becker anniversary clock #2088178. It was purchased by my grandfather. My father who recently passed away (93 years old) had no memory of it ever working.
I took it to a friend who's hobby is working on antique clocks and lamps. He got it as far as running for 15 minutes at a time. I then spent a month hand spinning the pendulum and bit by bit and it would run longer and longer. Then it ran non stop (a bit fast) for almost a year. Now it has stopped again and I was thinking maybe it was time for a winding! I put in the key, but it seems so stiff I'm afraid to force it, as I have no idea how hard I should try to turn it.
So that is my question. How stiff is the key to turn?  Thank you for taking the time to read my long-winded question.
ps I have done minimal work on watches, years ago. I have a ridiculous number of watches, though not many antiques.
Sorry for the delay. I will get those pictures soon. It has been running now for about a year, so I don't think it could still be fully wound, but I really don't know how it works. I just tried to turn the key and it moves a bit looser now. Counterclockwise, correct? What exactly do you want to be included in the pictures, angle, etc.
From what I can see the clicl and ratchet wheel are on the outside of the plate, that is good it  makes it easer to let down. If you have never let a clock down it wood be better if you bought one of these. You do not want to harm yourself or damage the clock.
https://www.cousinsuk.com/product/mainspring-let-down-tool-with-3-key-shafts
Thank you for the information about the tools to "let down" the clock. It sent me to a lot of reading and videos. I won't be doing anything right now because, wait for it.... the clock is running again! I know it isn't fixed, and I'll have this happen again, but when it does, I'll start with the information you gave me. I look forward to reading more on this site. Thank you
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
