Hi all, I have a seiko Bell-Matic 4006a, ihad problems regulating it and when I put it on the timing machine it was all over the place. One minute it was - 80 secs next + 200 so I started taking it apart and found the problem to be a broken pivot on the escape wheel, there was just enough of the pivot left to hold it steadyish hence the Watch was running ok but just losing 3 mins a day. The problem is now I cannot find an escape wheel for this model. I have tried cousins obsolete, jules borel  obsolete  and contacted a few sellers on eBay, so does anyone know of where I might be able to source one short of buying a complete movement which would definitely not be cost effective. Thank you in advance.
See if you can move the upper and lower stones closer to get this one fit in between.
I broke one not too long ago, arbor on it was completely gone. Had to get a used one off of local shop for the price I am affraid to publicaly anounce.
7 hours ago, AndyHull said:
According to ranfft ->  http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&Seiko_4006A
The balance is Balance staff Seiko 315470
These guys claim to have the balance staff -> https://vintageswatchparts.weebly.com/seiko-parts.html
Whether they actually do or not, I don't know, but you could give them a try.
Looking at the op’s post he needs an escape wheel not a balance mate
Hi,
speedtimerkollektion.com seem to have several 4006 watches/movements for spares/repair. Not cheap though....
They also show many parts but not escape wheel . Might still be worth asking....
The p/n is 251805 acc. To the data sheet from Cousins. Might be worth checking other sheets to see if the p/n is used in some other Seiko movement.
I had thought of that but it was going to be a last resort option, I have now managed to get one thankfully.
On 3/16/2019 at 10:33 PM, transporter said:
Is the escape wheel generic to other Seiko movements if so that might be your answer, I wonder what the part number is
It is 251.805 and I have now got one thanks to this site.
On 3/17/2019 at 7:36 AM, bsoderling said:
Hi,
Yes thanks,I had contacted them but they only had complete movements, I have now managed to get one.
13 hours ago, saswatch88 said:
I think I had gone escape wheel blind, I had looked at this listing and did not see his drop down list. Thankyou, I have now ordered the 251805.
glad you got it man update us when you get it fixed
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
