A Marvin For Christmas
WillFly
I've been looking out for something special for my Christmas present this year. And I thought to myself, "I wouldn't mind a wrist watch for a change..." :D
So I'm about to acquire this lovely Marvin military style model - complete with original Marvin Bonklip strap. Probably 1950s - brilliant condition and a lovely cal. 520 movement. But when it arrives (sob) it has to be put away!
Very nice watch Will, I love the fact that it comes with a bonklip strap of which I'm a fan. I have a Seiko military style dial fitted with one and I simply love it. The down side is, in my case, I have to be careful when I wear it...it feels it can open at any time although I'm sure it is simply me!
The Marvin arrived this morning and has been duly drooled over. I'm allowed to wear it for today - then it has to be locked away in a secret vault deep in a dark cave at the bottom of a vast mine in a faraway country. In other words, somewhere in one of the drawers in madame's bedside cabinet. Fresh pics below - and click the link for a spot of Marvin from 2011... https://www.youtube.com/watch?v=7vnY6m8HM0E
Edited by WillFly
Great watch! I had my eye on that one too! Almost identical to mine but in better shape. I have managed to polish the scratches out of the crystal for now. i don't wear mine everyday either. I will say this the winding mechanism on mine is like silk. It has such a smooth wind!
Great purchase! You will be very happy! Congrats!
http://www.watchrepairtalk.com/topic/877-my-timekeeping/
Will,
I very may have borrowed your phrase "winds like silk" as I cannot think of a better description more befitting. I do wonder the difference. It is considerable. My Illinois pocket watch is pretty smooth as well. Craftsmanship, I suppose.
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
    • Hello and welcome to the forum Dan. Used to know Middlesboro quite well, that was twenty years plus ago. Attached a little reading to get you started. TZIllustratedGlossary.pdf
