Does anyone know if this staking set includes tools to remove balance staffs. I've got an opportunity to get one at a great price and if I don't need to look for a Platax tool it makes it even more attractive. The documentation from Bergeon isn't very clear.
The key to removing balance staff is not to damage / bend the balance arm. The platax tool used correctly supports the arm and the correct tool to be used with a staking tool also supports the balance arm. However for this reason I always now remove as much of the rivet as I can before pushing out the old balance to avoid any possible damage to the arm.
Good advice in prior posts.
I've the C version of the type of staking set that the video that video in OH's posting has a link to. The D version has the addition of the base for the tool.
The Unruh-Max, the tool for balance staff removal, appears at 1:05 in the video. It doesn't come as part of the C set and I don't think it's part of the D set as standard.
There is one currently on e-bay UK which looks to be ok. Item 153398604657 (I've no connection to this item.)
I bought mine on e-bay a few years back following a prior post on this forum. It can be used with most staking sets not just Bergeon branded sets. I have used mine on a few pocket watches.
The K&D tool that you have a link to is a different tool but fundemenly is designed for the same task as the Unruh-Max. That is they are balance staff removal tools.
Whichever tool you choose to use to remove the staff, you will need a decent staking set of punches and anvils to rivet the new staff on to the balance wheel.
Sent from my moto g(6) play using Tapatalk
This is great stuff as usual. Thanks guys. Next question, anyone know of a good guide to using the fantastically named "Unruh-Max"?
I think clockboy has that tool. I'm sure he will be able to help you with this one. I would just turn the rivot away in the lathe to remove the old staff.
I have one. It fits into your staking tool and it shocks (via a spring) out the balance.However be aware that if it does not work due to a tight fitting balance damage can happen to the balance. I always remove some of the rivet first damaging the balance can be a real head ache.
That's the thing with the various "removing tools", they tend to work OK until they don't. I know not everyone has or wants a lathe, but it really is the best tool for removing staffs, my preference is to turn off the hub for zero risk of enlarging the hole.
I have used the K&D tool in the past, fairly often when I was working in a trade shop while in school. No lathe in that shop. I imagine it works as well as a Platax, which is to say pretty well. I still have the tool but it hasn't been used in 20 years.
I’ve never had an issue with using a Platax. I’ve seen balance wheels which have damage due to over-enthusiastic work with the graver when a staff has been turned down. But you could easily damage a balance wheel by incorrectly using a Platax.
I had an incident with the platax on a vintage Rolex it was tight & I must admit I did give more force than usual. When I tried to fit the new balance to was too loose. It may have been the new balance was wrong but I suspect the hole had stretched. Ironically a few months later in my BHI mag the subject of removing vintage Rolex balances was covered. It was stated the balances on the vintage Rolex were made of hard metal and the guy annealed them first before removing some of the rivet.
 Anyway, since then I now always remove some of the rivet.
On 3/6/2019 at 11:56 AM, margolisd said:
Thanks OH. But which one is the balance staff remover? I thought it would look something like this.
I spent a tense hour watching this guy's video for the process.  I have to admit, while he goes about it in the wrong way many times, he would be me if I talked to myself while working.  His frustration is familiar.
RMD
< Clearly, editing is too much trouble for him!:;)>
Edited by rduckwor
  • Haha 2
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
