3D Printed Cases
This may be old news but for me its new. As some of you may know I have been working on a few projects lately. One included a from scratch build. Ive benn tinkering with 3D Printed Cases and heres what ive got so far. The gold filament has produced a better than expected product. Sizing is a bit tough for fitment as the printer doesnt always print to scale but once dialed in repeatability is acheivable. I have a 170 and a 7750 planned for these case. I will post in those build threads but wanted to get this result out as Im pretty excited about the product. c0d6c6d9004c89e8d8d08afb791e015d.jpg0a5ba2bfe938d8c45a4c47f239a6995d.jpg
Sent from my SM-G950U using Tapatalk
Here's a trick you might like to try if you have the necessary capability. I have no idea how good the results are likely to be, but it is on my to do list.
Polish the case to a smooth finish (1000 grit or so). Next coat the plastic with graphite to make it mildly conductive, then copper plate it.
This would then allow nickel plating on top of the copper.
Strictly speaking this is probably better described perhaps as electrotyping or as electroforming rather than electroplating, as the substrate is plastic rather than metal, but lets not split hairs.
This is one of the methods used to produce bright shiny "metal" plastic parts, and is probably much easier to attempt at home than vacuum sputtering or sintering.
Simply fine polishing the metal filament model may produce a pleasing result, without going as far as to electroplate.
Caswell makes a spray. But even better there are conductive filiaments. Its def crossed my mind. What I really want to do before that is get my hands on an SLA printer. They have an much higher resolution and there are plastics that they use that can be electroplated from the start.
I'm not familiar with that brands products but I have used one conductive spray and the result depends lots of the preparation work.
Grinding with a fine sandpaper and spaying a couple of times with a grind with 2000 grit sandpaper after every layer gave a smooth surface. It's little like spraying a car.
I use the silverspray to make a gold plating.
Ive ordered some of the conductive filament. I have so many projects going on right now. Lol.
The filament should do the trick too. It was a while ago i tried out these products not just on watchprojects but also on mobile phone cases, for the kids.
The only disappointment was the thickness of the plating which seemed to wear of quite fast.So it seems the product I used isn't very partyproof ;) .
You could also use it as a mould to do resin cast / cold cast from. What resolution are you printing it at ? I'm not sure my 3D printer would be accurate enough
Not a bad idea. I have my eye on an SLA model. This one has a layer resolution of about 250 microns.
That is the one I currently have has a 250 micron resolution. The SLA is a resin base and the resolution is far better.
    • What this extra disk next to the pinion? Thats not part of the assembly
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it worked perfect 🙂 I'm very happy how this method worked out ! 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
