Hello and thanks for having this awesome community... I just purchased a mighty mouse watch on ebay from 1985 perfect condition however I dont know how to change the battery out and local jewelers dont have any clues as well. Even google resulted in nothing so hoping you folks might help. thanks much in advance Its a bradley time piece
Looks like a one piece case to me. The button on the back removes the crown and stem. Then pry off the gold bezel on the front. Hopefully the crystal will come off with it and the movement will come out the front.
This might be not possible, many "swatch" watches were built this way. The only chance you have is if the crown can be removed and after removing the crystal the movements comes out through the front.
It could also have a two piece stem. Not likely , but possible.if the button is for some reason not a stem release , you would have to remove the crystal and tilt the movement out.
