Swiss Emperor Watch - Any Good?
Some of the Roamers particulaly the ones with Brevette engraved on the caseback are front loaders if you hold the watch by the lugs and push on the crystal the movement caseback and crystal should come away leaving you holding the bezel , the crystal then lifts off and you can then remove the movement , as already mentioned some had split stems that would need splitting first but yours looks to be missing so no need to worry about that bit.
Need to see the caseback really to determine if it is this type but if it is it's easy enough
good luck
Andy
good luck
Andy
Hi Andy.
Yes, my one has Brevette ie Patent on the rear. Managed to remove crystal but stopped short of removing movement as I don't have a decent amount of time today. Maybe tomorrow.
Excellent! :-)
I've got a Ducati that just needs a battery!
I think yours only has two wheels though, doesn't it? [emoji1]
Took a look at mine under a loupe and realised why mine looked "fuzzy" compared to the one I just bought.
At first I thought because it was 10 years of constant use it had got scratched up. Nope, take a close look at this pic and think "ice crystals"
Took the movement out and cleaned the inside of the crystal. All gone now. Greased caseback and stem gasket.
Wonder what caused it? [emoji47]
Edited by ro63rto
Hi Roberto,
Looking in the crown post, is there a stem?
Anyway, this is what I woul do...
1st remove the chapter ring (the part with the minutes marked). Once this is removed, the movement should come out. If there is a stem then it may need to come out at an angle. I believe you will find it is a 2 piece stem with the crown part missing. Now that I think about it, even with a 2 piece stem you may find the movement will come out easier if you get the side opposite the crown out first.
Note! Save the crystal, these watches can be a pain to source crystals as the seal depends on the thickness of the crastal edges. If you look closely you'll see a step in the crystal edge (assuming its original).
Anil
Finally got the movement out.
The chapter ring comes off real easy.
Now for the bad news.
No crown OR stem! Looks like a spider has taken up residence in the resulting void [emoji35]
So the search is on for new stem and crown.
On a higher note, the movement is the more sought after (or so I have read) MST436 and looks to be in very good condition plus it has the original 7 jewel Rotor.
All in all a nice watch. Acrylic crystal is in Very good condition with only 2 light scratches. Easy enough to remove and I think the dial is in pretty good shape too.
Cousins list the male inner as well as 2 other stems didn't mention the female outer part though so whether the other 2 are one piece stems i don't know
Found a stem and no need to register AT ALL [emoji1] €10 plus €3 postage from Netherlands.
Now for a crown.
Roberto,
Beware ....instead of selling the crown you are more likely to buy a crownless Roamer hoping your crown will fit!
Been there.....
Anil
Stem arrived from the Netherlands.
I think they sent me the wrong one. Its not a two piece stem ie the crown screws to this one they sent instead of one that clips onto it. [emoji35]
That's a bummer, especially when it's an International purchase. :-(
Its a pain. Only £2 postage but the hassle. ... Thought I finally found it.
I found on Boley that they list the stem as Part 401.
This pic on oldswisswatches shows 401 and it looks similar except the resolution is bad. I'm confused. Wish there was someone with an exact watch to compare it with.
Edited by ro63rto
The company said they supplied the correct one ( even though I emailed them the model before ordering) but they will take it back and refund me.
Only thing is Royal Mail are theives and want around £5 to post it back. Not worth it.
Anyone need an MST430/436 threaded winding stem for a "Normal" watch case? [emoji16]
2765 is the correct part number. This is a split stem version and is the one required.
Called a "Stem for water resistant case"
Thanks Mark.
They have refunded me even though I haven't sent it back due to cost of postage.
Now to find someone that can sell me it using paypal as I no longer have credit cards.
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile and is supported by the literature:   A review on control of droplet motion based on wettability modulation principles design strategies recent progress and applications.pdf   However the whole point is that we have less mobile oil so an oleophobic  would see to be the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic (beading) and cohesive/adhesive resulting in low mobility?? This may explain the high price??
