Longines 6942 balance cleaning.
HSL
The Longines 6942 is quite straight forward to service but since it is equipped with the KIF-ultraflex shock absorber some might decide to just clean the whole balance in one-dip, oil it through the
jewel hole and leave it with that.
So here is a small walk through of how one might do to dismantle parts of the escapement to get this sorted out in a different way.
When you look at the shock absorber through a Lupe you can se it has a wide and a narrow slot on the brass ring. On mine the narrower slot is positioned to the left.
With an oiler I push the spring on the narrow end downwards. the spring should pop up a bit so lift it up to the position you see in the picture.
Flip the movement, make sure no power is in the mainspring by lifting the click spring. Push the winding stem back in into the
winding position. Gently wind an see if the train moves free. Make sure you clean the pallet fork jewel holes with a peg wood.
Put back the pallet fork, apply some tension on the main spring and check the action on the escape with the peg wood. Move the pallet fork back and forth. Leave the pallet fork in the upper position.
16 minutes ago, rogart63 said:
What use does the +- have on the beat error arm?
Guess they just symbolize the direction to go when adjusting the beat error. It isn't like on the regulator where you make the spring length shorter or longer and by that increase or decrease the oscillation frequency. Should have been R & L since you center the impulse pin in relation to the pallet fork with it,
Edited by HSL
Somehow statements like that comes back to bite you in the ass.
Even though this contraption is on the beat error arm it can be used to regulate the rate, python port regulator, hence the + and - .
It has a smal brass disk attached to the center of the small setting screw, it moves back and forth. Due to the friction between the brass disk and the regulator arm it moves it in micro steps.
For some reason one always seen them but never given em a closer thought.
Here is a pic of a spare I had. Notice the easy studless hairspring attachment.
i didn't see the screw. I thought it was a screw from the top. But it's a nice idea to be able to adjust the length of the spring.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
