How do you reset a bezel and crystal on a watch which the movement comes out from the front?
Ladies and gents,
This is the challenge watch ...a Skagen SKW6247 Men's Ancher Stainless Steel
I proceeded to do a very simple task, some of you would consider extremely easy, changing a watch battery.... read on it gets more interesting...
Well the back was extremely tight so it took quite a bit of leverage with the pry tool but it did come off and from my novice experience what is difficult to take off is usually difficult to pop back in.
So I took out my handy dandy back case press and proceeded to pop the back in when the front came out....as did the movement and the minute hand was loose (so I will have to address that later)
The crystal is part of the bezel and it all came out when I attempted to press the back in , makes sense since that's the only way that you can change the movement which is 42 mm and the back entry is 36 mm.
The bezel seems to have a small lip and I am absolutely mystified on where to line this up in order to press it back in.
My current experience is when you don't know what to do, you stop, put the watch away until you find a solution.
Is there a technique that is used to pop the crystal/bezel combo back in for these scenarios ???
Signed
Truly perplexed novice..     :geek:
Edited by MilTimeCan
typo
11 hours ago, MilTimeCan said:
Ladies and gents,
Signed
   Rumpole had  had a solution for similar problems,  Chatto fleet street I think?   all kidding aside,  it may be a new import watch that is not  repairable .  vin
Hello,
I just did the same work to my skagen chronograph quartz and the crystal had a thin gasket around it that was set with mastic / UV glue.
The gasket was not salvageable but the crystal went back into the bezel just fine with UV glue.  Hope this helps.
8 hours ago, cduke said:
Hello,
makes sense, there's nothing I can see that will connect the bezel to the case.
could be it was a real challenge to pry off the back and it seems almost impossible to press it back in ...Hope u are well Vinn !
    • Hi, this is the first place I found when looking for advice so I hope someone could advise me.  Im completely new to touching watches but I’ve always wondered how they work.  I’ve bought a cheap movement, an ETA replica to take apart and rebuild.  Im thinking I’ll need some screwdrivers, tweezers, movement holder and a loop? My goal is just to have a go first and see if I enjoy it enough before buying more tools.  Do I buy cheap tools for now and get better quality tools later if I enjoy it like I think I will? or will the cheap tools be a pain and take some of the fun out of it?  With quality tools being relatively expensive I’m unsure what to buy.    Any advice would be greatly appreciated!
    • Yeah I have seen 44-56 documented for Elgin 18 size elsewhere. I have the style of gauge that's like a set of feeler gauges and I never noticed before today it is faintly stamped "Elgin". Pictured is the way I have been measuring. I am going to go to a larger jewel than the 42 that had been in there. I recently won an auction on a big set of Fitrite jewels all in the little bottles, to discover that the what's actually in the bottles bears no relation to the chart of sizes printed on the box. In most cases it seems to be all mixed so in fact I have about 24 little bottles and thousands of assorted jewels of all diameters and lengths, which is better than nothing. But since I don't have a micrometer with a table, measuring for the exact diameter will be a big job. Instead I will test a lot of them in the fork slot the same way I measure with the gauge. But this is still the next thing. I have to get the escapement to unlock first.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
