I'm having some unexpected behaviour from a eta 7750 that I'm trying to regulate after servicing.
I went through service procedure using correct lubricants.
Everything went fine. Actually I have some doubt on lubrication of incabloc wich I'm not sure I did correctly since I'm afraid that too much oil was placed in one of the two stones.
The fact is that when I finished I wasn't brave enough to clean and lubricate it again ... shame on me but I felt that task to be very very difficult.
Anyway after reassembling the watch I had it at my wrist for a week and it showed a great consistency at -10 sec a day.
It'a stop grade movement and resting at night in DU, DD 9UP and 3UP positions always showed something between -14 -6
I was very happy with that result and I thought that a little regulation would have brought it to a very fine time keeping.
Then I reopened the caseback and slightly moved etachron arm, that was resting in a nearly neutral position, in the + direction.
Nothing happened (measuring with timegrapher open source app)
Did it again, another slight push.
Nothing
? ok I must have gone the wrong direction, then pushed all the way toward   -
Nothing happened.
Ok this is annoying, all the way toward +
nothing
here I am,
what I'm I missing?
How come moving the regulator arm from - to + does not make any variation?
I'm lost
19 minutes ago, jaycey said:
Is it a ETA movement or a Chinese clone?
Definitely ETA. Actually it's an Omega version installed in a Speedmaster Reduced.
Top grade with glucydur balance wheel.
