Fitting A New Watch Stem.
Geo
When fitting new stems to watches I use these tools :-
Digital calipers,
Fine grade diamond lap
Wire cutter
Pin vice
Now for fitting.
(1) Hold the stem in the pin vice and screw on the crown tightly by hand.
(2) With the movement fitted correctly in the case, insert the stem until it locks in place. Now measure the gap between the case and the underside of the stem. In this case it is 2.16mm.
(3) Subtract 0.2mm from this size and this will give the amount to remove from the stem. In this case it will be 1.96mm which will give 0.2mm clearance below the crown when fitted to the watch.
(4) Now remove the crown from the stem and hold the stem very tightly in the pin vice, then place the pin vice and stem between the jaws of the digital calipers then zero the calipers.
(5) Remove the calipers and without touching the zero button set them to minus 1.96mm. THEN RE-ZERO THE CALIPERS AT THIS LENGTH The wire cutters are now used cut off the excess thread leaving a small amount to be filed to the exact length.
(6) All that is required now is to dress the stem with the diamond lap a little at a time until the calipers read zero.
(7) Finally screw the crown on tightly and it should be ready to fit to the watch without further adjustment.
I find that this method cuts down on trial and error.
FOR SCREW DOWN CROWNS.
A) Screw down the crown tightly onto the case without the stem and measure the distance nbetween the bottom of the crown and the case.
B ) Screw the new stem tightly into the crown, then insert into the watch until it engages and locks into the movement.
C) Press the crown down firmly as far as it will go and hold it there.
D) Using the vernier callipers, measure the distance between the bottom of the crown and the case.
E) Subtract the size determined in (D) from the size measured in (A) then subtract a further 0.15mm from this size. This is the amount to shorten the stem by. This should allow the crown to screw full home without compressing the stem too tightly between the movement and the inside of the crown.
F) Cut the stem leaving it slightly longer than the size determined in (E), and dress down to size using the diamond lap and vernier callipers as described in the original post.
G) Screw the crown onto the shortened stem and check fit and function, before using a tiny spot of Loctite 221 to secure.
Click here to view the article
  • Like 17
OOPS, I forgot to say the calipers had to be re-zeroed again!
Please edit this into the original post if possible Mark.
Thank you Geo..For my part I purchased the same type of stem and I measure the same length and I cut and I file the end of the threads of the stem. for me, this solve the problem..I'm lucky because it has never happened to have a watch with a piece of the stem. It is also rare that I buy a watch with a broken stem..Sorry for my bad english ;) your explanations are the best..
Your wish is my command :)
  • 2 months later...
  • 4 weeks later...
(A) Screw down the crown tightly onto the case without the stem and measure the distance between the bottom of the crown and the case.
(B ) Screw the new stem tightly into the crown, then insert into the watch until it engages and locks into the movement.
(C ) Press the crown down firmly as far as it will go and hold it there.
(D) Using the vernier callipers, measure the distance between the bottom of the crown and the case.
(E) Subtract the size determined in (D) from the size measured in (A) then subtract a further 0.15mm from this size. This is the amount to shorten the stem by. This should allow the crown to screw full home without compressing the stem too tightly between the movement and the inside of the crown.
(F) Cut the stem leaving it slightly longer than the size determined in (E), and dress down to size using the diamond lap and vernier callipers as described in the original post.
(G) Screw the crown onto the shortened stem and check fit and function, before using a tiny spot of Loctite to secure.
This is now added to original post by Geo.
Edited by Geo
  • 10 months later...
Hi Sendikumar,
The screw down crown has a spring between the stem and the crown (it is part of the crown ensemble) that creates a certain tension when properly screwed into the case tube. The spring tension translates into a shorter stem -- since the spring supplies the rest of the length -- and in the end it "takes back" that length to seal the watch...this is normally used in diving watches. Did I confuse you more? I'm not very good at explaining!
Cheers,
Bob
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
