Strange behavior in old movement
Hi again,
Working on an old (as usual) movement from one ofthe tank style watches mentioned in another topic.
Had to fit a new ms but otherwise it all seems pretty ok after a cleanup.
And the thing runs but with a strange bahavior on the timegrapher app. Screen shot attached.
The beat error switches between a decent 1 ms to around 6 ms and during these periods the curves slope heavily, indicating a drastic and immediate slow down. The behavior is periodic and switches several times per minute in a regular fashion.
I suspected over banking and tried a weaker ms that gave a lower amplitude. No change.
I also shifted the hs to check if the beat setting influenced. No change with a different beat setting (even though the beat error changed a lot).
All pivots appear nice and straight to the eye.
My assumption is that this problem should be located close to the escapement, considering how the error repeats...?
Any advice or experience is appreciated.
Hi there:    The got no pic you talk of. anyway
How about amplitute in various positions, face up/ down , side and oblique.
wobling escape wheel? .... fork arbor qnd staff  end shake, .slight push down on balance staff jewels too see if it stops balance wheel.
Regards joe.
No need to remove any part to produce the aforementioed data.
Next.
1. Loosen the escape cab screw if any.
If no change. One drop of lighter fluid on staff ,escape and fork arbor jewels
If no change, try removal of cabs to see the jewels, broken....etc
If none observed, remove balance cock and fork bridge. Oil jewels and wind manually for several seconds. Observe.
While at it check pallet alignment as well.
Timegraph dose not diagnose.
Velocity fluctuation as you describe is common and expectedly from escape wheel.
Regards joe
Hi guys and thanks for feedback.
Was working through the balance and 35587c44267d614226adec35cebb0b11.jpgescapement along your advice when one of those things not supposed to happen... well, happened... Had a Major flip of the balance cock while holding the wheel and ending up with a h/s all twisted and mangled. Unless I can find a part, I guess I will never know what was causing the problem.
I have attached a photo of the marking on the movement which is unknown to me. If anyone knows of this I’m grateful for feedback to start a search for parts.
Hi,
Not giving up on this one yet....
Here are a couple of photos that hopefully can help to id this movement.
The key-less part is in my experience somewhat unusual as the yoke and spring are on separate sides of the winding stem. I usually see the spring sitting right beside the yoke. Maybe this ”feature” can be of guidance....?
Hi,
Thanks to Watchmaker and WLS1971, two excellent watch sleuths, two out of three ongoing identification questions have been resolved.
A Derby 33 and a Bifora 102, no common movements on my list. Had never heard of the brands before. But amazingly enough some parts are available and I have some incoming.
But this headache remains...
I just noted a small imprint on the balance cock (a "V" it looks like) and was wondering if that perhaps rings a bell somewhere...?
A close up photo is attached.
    • https://watchguy.co.uk/cgi-bin/files?showfile=Venus/Venus 178.pdf&filename=Venus 178.pdf&dir=Technical Manuals&action=documents   The hour recorder is driven by the barrel and it will only stop if it is held by the hour recorder stop lever 8690. So I would check if this lever (powered by the spring 8691) is really holding the hour recorder in the "chrono off status". I haven't worked on a Venus 178 so far, but on an Omega 861 I chose 9501 grease for the friction spring as it's moving very slow at quite high tension.
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
