Well..........
Ive pulled it all apart carefully and noted that the suspension was bent and twisted at the fork bridge bit, that was not at all apparent when it was assembled. I straightened it and untwisted this section.
--The suspension strand has a slow gradual twist of about a full turn over its full length below the fork, but I thought, might as well press on clean it all anyway. Probably need a new one....
I sonicated it all in the tank, which took all the crud off and then in light of the above advice on light lubrication, I applied very sparingly Moebius 9000 to the pivots--Its the thinnest lightest oil I have as I don't usually do anything other than tuning-fork movements...
I didnt take the mainspring out of the barrel, but did wash it all out with naptha, working the spring a few turns winding with the key etc, it was very clean in there TBH, the clock doesn't seem to have much evidence of wear anywhere, even the pallets show no polishing marks of wear...
I'm thinking this clock never ran!
Reassembled it and potched around with the beat as best I could--Hmm, That was tedious! Trying to get the balls to rotate whilst not swinging back and fourth as well.....
So far--its run for an hour, holding just a fraction over one complete turn of the balls.....
