Seiko 6119-6400 repair help
Hi everyone,
I'm new to the forum and watch repair. It's great to have a resource like this when things aren't working as they should!
I recently bought a 6119-6400 with a couple of known issues that I'd appreciate some assistance with.
Firstly, the internal bezel is very stiff, it turns but with quite a bit of effort. Secondly, the quickset date works, but the crown sticks once pushed in and the day won't change when the crown is pushed. It does advance when changing the time between 9pm and 1am though.
Lastly, I confess I'm not much of a fan of the hardlex crystal and would love to try a slightly domed sapphire (it's a UFO, right?). How do I find something to fit, any suggestions? I have the sense that trying any old 33mm crystal is unlikely to work.
Thanks in advance for any help you can offer!
Hello Peet,
On this friendly forum before making a post for help or advice. We like new members to introduce themselves. Just say a little about what you do and about yourself.
We like that to go into the Introducing Yourself Here. This is the link.
https://www.watchrepairtalk.com/forum/23-introduce-yourself-here/
Members please do not reply until he has introduced himself.
Hi all, any thoughts on the items above? I have completed a teardown and rebuild of the calendar works, which has helped with the sticking of the crown. I also noticed the day does advance when the movement is out of the case but there doesn't appear to be enough travel on the stem to activate it when in the case. Would this suggest the stem has been replaced with one that's too short?
Also, in looking at the inner bezel, it appears like removing it and cleaning thoroughly might be a good place to start. Any ideas on how to remove the outer ring surrounding the crystal though? It seems I'd need to do this to access the inner bezel. Finally, any grease or oil required for this bezel to function smoothly?
Apologies for the barrage of questions, thanks in advance for any advice
  • Similar Content
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
    • There are some parts on Ebay for the seiko 6020A, it may just be a waiting game for someone to strip one down, NOS will be more scarce . K would strip your movement down to the module then start looking at other seiko movement to see if that coil is used, then seek out a seiko part dealer. Also Retrowatches youtube owner Mike may give you some advice try him on his site . He also hangs around amateur watchmaking groups.
    • I would agree, in order to work harden something you need to exceed it's yield strength when it moves from the elastic zone to the plastic zone and you get permanent deformation and work hardening which is fairly close to its failure point, relatively speaking and dependent on the material/alloy of course. In theory you can load something constantly within its elastic range and not suffer work hardening issues.
