Accutron and Vintage Enthusiast
akkatron
In 2011, while still in college, I was watching modern marvels one Sunday, and a short segment about the Accutron came on. I was intrigued, yet never really was a watch person. I saved up and bought a 214 hope it to later convert it to a Spaceview. Since then I have been repairing all types of watches, especially Accutrons. My most recents are an Electroquartz and Ultraquartz. I have no formal training, but love new challenges. If you ever have Accutron questions, I may be able to answer them! Can’t wait to be a part of the forum!
  welcome - welcome.      the Bolova Accutron history  is Very interesting, but not well understood buy the collectors or the "watch mechanics" (electronics).   i  have a spaceview (as found)  and several emty nice accutron cases.  i am shure you will have a lot to offer this good forum.  vin
Hi Akkatron. Welcome. I have tried never to get involved with any hummer of any kind. Interesting tho they are they look like a basic Hartley Osc and a tuning fork for primary pulse control.  I have info somewhere but I stick to mainly mechanical and quartz !. Many years ago I did a terrible deal and swopped a speedmaster for a F300. Heap of junk in my opinion. I wish you a better experience. Best regards, Mike.
Thanks all! The tuning fork watches are nothing much to fear. Again, I pretty much taught myself to work on them and have become quite comfortable working with the index wheels and other small parts. Yes, a Speedmaster fetches a great price these days, but so do certain f300Hz.
The problem with the f300’s is that the date wheel is plastic, and the slipper clutch used to protect the date wheel teeth has break-over torque probably 4x what it needs to be (even when lubricated). I will always recommend that the date be quick-changed between the daytime hours to avoid the sticky clutch. Otherwise, you COULD break a tooth.
The other issue is the index wheels. If the train clutch goes un-lubricated for too long, the setting mechanism will override the indexing teeth in the forward direction. You will know this is happening when the second hand quickly advances when advancing the time. Too much of this and the indexing wheel teeth will eventually flatten, like Grandma’s flat tappet camshaft lobes.
Now, I’m off to make a post about the new Tudor I received!!
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile and is supported by the literature:   A review on control of droplet motion based on wettability modulation principles design strategies recent progress and applications.pdf   However the hole point is that we have less mobile oil so an oleophobic  would see to be the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic (beading) and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
