I'm servicing another of my aircraft clocks.
Other than the hairspring which was swimming in 3 in 1 oil the rest of the movement was bone dry.
Its been stripped and cleaned now and tonight on reassembling it I noted the cannon pinion is too tight and wont allow adjustment of time.
On close inspection I can see someone in the past has tightened it either with wire cutters or in a cannon pinion tightening tool, but has crimped the tube too much.
I can clearly see the divets inside the tube on the cannon pinion and need to just loosen it ever so slightly.
I am thinking on running a broach through it and checking it constantly until I get the correct fit unless anyone has got a better suggestion.
It may sound weird but a good way to adjust it is with it mounted on the center wheel shaft, squeeze it at the crimp with fine nippers. It will actually relieve some of the tension. Otherwise you can hit it with a broach, but it's very easy to go too far.
This is exactly what you will have to do to ease it off slightly.  As we say in Scotland ca canny taking very little at a time until the friction is just what you require.
Edited by Geo
I went down the path of broaching, little at a time and lots of checking. I possibly broached it a tiny more than what would be considered perfect, but I think it will be ok, time will tell.
The clock is now assembled and running, amplitude around 230 degrees, beat 2ms error which could be improved on, but will leave it as is for now. Keeping time between -1 and +5 seconds on the timegrapher.
I'll let it run over the weekend and see how it is performing after that, but I'm reasonably happy with it.
Next will be my Waltham aircraft clock...
On 9/26/2018 at 11:15 AM, clockboy said:
What ever method you choose support the inside with pivot wire or something similar or you risk distorting it.
Clockboy is right.  I recently encountered this problem only in my case mine was too loose so I thought I'd try to tighten it.  I don't have a cannon pinion tightener but I do have a stump in my staking set which can be used for the same purpose.  So I did.  I used a blade punch and gave it what I thought was an ever so slight tap with my brass hammer (maybe it was a mistake to use one?).  Well, in spite of my best efforts, I over-did it.  And I forgot to put in a supporting wire to prevent deformation (I had been taught this!!).  Now my cannon pinion is slightly deformed! :(  Lesson learned!
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
