PLEASE HELP ME TO IDENTIFY THIS MOVEMENT
ok, have you try a watch that twist the bezel to open it? and use what tool? I try to pry the bezel and it does not work.
This is the link I use to Ranfft : https://web.archive.org/web/20230305223408/http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk The search function doesn't work, so the link should show all the movements.
By Hawaiikook808 · Posted
Thanks, Praezis. I'm going to hunt for one. -
Why do you doubt? It is a common current name for transistors with included base and base-emitter resistors. They are not „digital“ by itself but can be used in digital circuits without added components. Frank
That will need to come out the front, the dial is bigger than the movement. If the case has a removable bezel then take that off, if not then remove the crystal. Everything should then come out through the front of the case.
