Hi from Maryland USA
DPhillip
Hello,
I joined last weekend but realized I posted as a reply and should have opened a new topic - I have a small collection of modern and vintage watches and just recently got two of the windups below working again after they seemed to be stuck for years.  This site looks like a great place to learn how to take care of them properly.  I also hope to learn what is needed to fix my Lejour chronometer, which I accidentally broke recently.    My vintage watches are all gifts from my father, who likes to collect one here and there; none are high value but all are interesting for their connection to history:
Here is a list and I am posting photos:
Modern:
Orient Mako II automatic dive watch (brand new)
Pulsar quartz chronometer (dates from approx 1990)
Seiko quartz dress watch
Vintage:
Lord Elgin mechanical (runs)
Waltham mechanical (runs)
Elgin DeLuxe Shock Master mechanical (runs but needs a back - it disappeared)
LeJour Chronometer (needs repair)
Duane
Maryland/USA
Thank you for the replies - I am happy the photos came out well and turned out to be easy to post.  As it happens, #4 and # going up from the bottom have issues.  My father just recently gave me #4, an Elgin with a screw-on back.  It works great and keeps time very well - but the back is missing!  He wore it quite a bit and said the back worked itself off while he was walking and he lost it.  Not sure if this is a bad idea but I am currently winding it daily and leaving it inside a closed box, hoping it won't pick up dirt.  Let me know if this is stupid.  I don't know if I will ever find a correct back for it or if I need to get a different case for the face and movement.
#5, I plan to post a repair advice request after a bit - this one if from the 50s or 60s I think.  It looks different, perhaps earlier, than pictures of LeJours I saw online.  It has a Valjoux movement.  My father, a retired U.S. Army Colonel, gave it to me when I was commissioned as a 2d Lieutenant in 1982.  I wore it on active duty in Germany and for several years after.  Eventually it stopped working and one of the small hands fell off.  But it turned out the watch itself just needed a cleaning.  A reputable, reasonably priced watch repair professional in the town I lived in took care of both about 10 years ago.  I then moved a significant distance away and later the watch stopped again - or so I thought.  I took it to someone else, who took it apart and told me it would be expensive to fix. Turned out he was wrong - I took it back to the person who had cleaned it and he had it running almost immediately - apparently I was not turning the crown hard enough and was thinking the resistance was a jam of some sort.  But it is normal for this watch.  But my watch guru also said two screws that fixed the movement in the case were missing - the movement was bouncing around inside.  So the person I had just recently taken it to apparently lost them.
Not happy about the screws, I wanted to see where they were supposed to go and removed the movement from the case.  This required pressing a detent and pulling the crown out.  Being an idiot, I forgot to press the detent when I replaced the stem.  And damaged the watch, apparently.  Everything went out of line.  My good repair expert looked at it again and reassembled it, but said parts to really fix it are unavailable.  He is very elderly and sick so is now out of the picture.  But I really want to fix my watch.
DP
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
    • There are some parts on Ebay for the seiko 6020A, it may just be a waiting game for someone to strip one down, NOS will be more scarce . K would strip your movement down to the module then start looking at other seiko movement to see if that coil is used, then seek out a seiko part dealer. Also Retrowatches youtube owner Mike may give you some advice try him on his site . He also hangs around amateur watchmaking groups.
    • I would agree, in order to work harden something you need to exceed it's yield strength when it moves from the elastic zone to the plastic zone and you get permanent deformation and work hardening which is fairly close to its failure point, relatively speaking and dependent on the material/alloy of course. In theory you can load something constantly within its elastic range and not suffer work hardening issues.
    • Probably easier to get a complete new movement - but CousinsUK list it as discontinued. Maybe someone on here knows a substitute movement ?
