Is your order placed Will?
What an amazing piece of kit, the only thing that would make it better in my eyes would be to have it in a plain case. :-)
Roger Smith's watches are absolutely beautiful - as were George Daniels' - all out of my price range unless I sell my house!
Wowers!!
That thing is a pocket watch for your wrist!
I admire the micro-engineering and the amazing finish of the piece, but it's not my cup of tea.
For the same money I'd by a Daniel's watch instead, that to me is watchmaking in it's purest and most elegant.
PS. From what I've read it's a 7-10yrs wait on new RW Smith.
I just ordered 2 but had to cancel...they were not expensive enough and the built in toilet didn't work well! I figure I'd look at the Daniels better! :)
Lawson, we can order a Daniels between the both of us and take turns wearing it! How about that!!! :)
On a more serious note, I believe they are trying to find a design that is trendy and at the same time successful...something like the Oyster from Rolex that has such a large acceptance and other manufacturers tend to "homage"....
Edited by bobm12
I want the video of the service of this watch !!!
Now that would be something to watch. I wonder if they would lend Mark one for assessment!
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
