I have a pocket watch that required a balance staff replacement. I've bought a NOS original one. The length fits, I even mounted it onto the balance and then onto the movement and everything checked out.
Upon trying to fit the roller I realized that it wouldn't fit. From research they made 2 versions of either balances or balance staffs or I don't know what exactly but the bottom line is that all parts are genuine, it's just that I have the roller or staff from one version and the rest from the other version (the hairspring collet also fits so only the roller hole is the issue).
You can't really find these parts and I don't want to invest anymore so I was wondering if it would be possible to simply enlarge the roller hole.
I don't have a lathe but I have ordered some mini-drills that come in all sorts of useful sizes. I would have to enlarge the hole by about 0.8mm.
It would have been helpful if I could find a really thin file to do this or maybe use some sort of a wire that behaves like a file but I doubt it.
Thoughts ? Suggestions ?
The pocket watch isn't an expensive or special one by the way so that's why I'd like to give it a go rather than invest a lot of money.
Oh this is exactly what I'm looking for, I think.
Are these basically "needles" with a texture similar to that of a file ? I can't find a close-up shot.
No broaches are five sided each side is a cutting face you insert and twist and the faces cut as you do so, they must be used at a perfect 90 degree angle to cut a perfectly centred hole, similar broaches are used in jewelling tools to enlarge jewel holes, the German ones that Cousins sell are cheaper than Bergeon and are very good the Indian ones I would give a wide berth.
And could someone give me any pointers as to how I can hold the roller into place ?
It looks like this. It would have been nice to have a vise with rounded jaws but I don't so...
15 hours ago, oldhippy said:
If you have a watch vice hold it in that.
I don't. Is there even such a thing ? :blink:
1 hour ago, oldhippy said:
Perhaps I should have said watch movement holder.
Chopin was asking about a way to hold a balance roller. Can't use a mov.t holder for that.
I had a star watch movement holder and had no problem. Here it is, you can  screw it up and it will hold, the same as the movement holders I pointed out.
The roller is very small. These holders have too large gaps to actually hold the roller.
I could use a normal vise (I have a small one) but it's hard to keep a round disk in place with a vise especially since, if at some point the roller moves or jumps out of the vise jaws I might damage it or break the roller jewel itself.
I'll figure something out I guess. Was thinking of making a hole in a cork screw or maybe a piece of wood (this one might be a bit more complicated...) but it still wouldn't really hold the roller in place if I want to drill the hole.
Opening a roller by 0.80mm is a lot, and it looks like a steel roller so going will be tough with a broach. Possible you don’t have the wall thickness to take that out even provided you have a good way to hold the roller and some buttkickin broaches. Best would be to turn down the staff.
    • Nice rescue. I like when a few with heavy patina are worn in rotation with nicer watches of a collection. Frankens, too so long as they aren’t passed off as something else. My experience with these Seikos is they tended to disintegrate on their own so finding correct parts to put an original together is near impossible…
    • Some answers from my view screwdrivers - if the bodies are ok for you maybe only look at changing the blades if possible, probably 100 and 140 first. loupes - 3-3.5 is what is normally recommended for disassembly and assembly, 10x for inspection  digital microscope - not great for working on movements as there is no depth perception, great for inspection and taking photos to post here 😀 automatic oilers - a bite marmite/vegemite at times, various opinions, some swear by them, some use them only for certain jewel settings others don’t care for them at all. They are not at all necessary, the usual alix etc. ones are fine and you don’t need to spend a fortune. They are very subjective though, you may end up making your own from a needle and peg wood because you like it just so.   can’t help with the Geiger counter, I’m one of the ones who don’t get freaked out about it. There is a legitimate concern, however as long as your not licking the dials/hands, or snorting the degraded old powder you are likely to be absolutely fine.   Tom
    • If you've got a stem for an ETA C01.211 then it should be correct. The other possibility is that the tip of the old stem has snapped off and is still in the movement. You can compare the piece your removed to confirm it's correct and not broken. Photos as always would help.
    • Thanks for the reply! How do I find out exactly what replacement stem i need please! I’ve just had at that pdf file you’re just sent & i can’t make head no tails of the item required mate! Sorry to be a pain!
    • Game on! ST36 has arrived, but there's still a few questions and I'd be grateful for your help. I've got a set of cheapo Chinese screwdrivers that I bought years ago, so I'll use it for now for learning. Decent tweezers in the post. I also have a clip-on cheapo Chinese loupe 5x. Looking at the ST36, I am guessing that I need a 10x? I happen to have a (cheapo) digital microscope too - am I better off just learning to work under the microscope right from the start? For oiling, am I really better off getting automatic oilers, or should I learn with regular ones? Any of you folks use geiger counters? Are cheap ones (~£20-30 off ebay) good enough for checking watches, just in case they are hot? I intend to avoid lume unless it's tritium, but you never know what you're dealing with.
